bolt size for Hemi engine mount. #2021020
02/27/16 11:55 PM
02/27/16 11:55 PM
Ohio
dannodude1 Offline OP
Ohio
What I need is the bolt dia. for the bosses on the block. I forgot to check the block before I left for work. How to spend my work night on moparts.
Re: bolt size for Hemi engine mount. [Re: dannodude1] #2021046
02/28/16 12:38 AM
02/28/16 12:38 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Hang tight, think I have the Tin Man bolts on my shop shelf from the conversion mounts.Think they are 7/16ths coarse. Hold on a few.
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: bolt size for Hemi engine mount. [Re: dannodude1] #2021056
02/28/16 12:50 AM
02/28/16 12:50 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
OK, 7/16" coarse thread 1" of thread under the head, takes a 5/8" wrench.
Hope this helps!
Re: bolt size for Hemi engine mount. [Re: Sixgun] #2021088
02/28/16 02:19 AM
02/28/16 02:19 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Size is correct. Factory used studs and nuts, not bolts. YMMV
Re: bolt size for Hemi engine mount. [Re: NANKET] #2021115
02/28/16 03:18 AM
02/28/16 03:18 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Re: bolt size for Hemi engine mount. [Re: dannodude1] #2021116
02/28/16 03:18 AM
02/28/16 03:18 AM
Ohio
Ohio
Thank you . I found some . Im using the bolts for mock up. Need to do some modification to get the beast into this dart.
