Dana questions #201902
01/23/09 12:51 PM
01/23/09 12:51 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I've just bought a Dana for my Dart from a guy over here in England.
It measures 52" wheel to wheel mounting, the problem i have, is that the yoke is right in the centre, the offset on my 8-3/4 is 2-3/8" . the drivers side tube is 1" shorter than the pass side, although the shaft is 1" longer.
My plan is to cut a section from both tubes but the pass side, i will cut 1" longer and swap them side for side, giving me my 2" offset back.
I am also thinking off making new front leaf mounts but a little longer to push the axle back a little, is this feasible and could there be any negatives.
BTW, If you are reading this Cass, thanks for your time to quote me but the exchange rate has killed the pound against the dollar, making it ridiculously expensive to buy from the US at the moment.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Dana questions [Re: deaks] #201903
01/23/09 01:26 PM
01/23/09 01:26 PM
Q
Quicktree Offline
Quicktree  Offline
Q
the one on my challenger is the same way. I am not going to worry about the inch. it's really hard to notice and I don't see it causing a problem. I'll let you know soon. it wont be long before it's done.
Re: Dana questions [Re: Quicktree] #201904
01/23/09 02:04 PM
01/23/09 02:04 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Quicktree
The Dana came from a tube chassis Road runner originally owned by Dave Shultz, i think the offset is more on A bodies than B and E.
Can anyone tell me how critical is the offset and who has moved their axle back and what were the ramifications.
Mike
best 60ft 1.36
Re: Dana questions [Re: deaks] #201905
01/23/09 02:06 PM
01/23/09 02:06 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I think an ebody is close to 1-7/8" not positive though.
Re: Dana questions [Re: deaks] #201906
01/23/09 02:15 PM
01/23/09 02:15 PM
Cab_Burge Online work
Cab_Burge  Online Work
slide the rear end under the car and center the brakes in the wheel wells and take a look at the pinion location, if it is not what you want then fix it having the rear end housing offset to the right or left is like having it higher or lower than the transmission, angles are needed to make the U joints work, it really doesn't matter which way the angle differences are, up, down, left or right IMO
Re: Dana questions [Re: Cab_Burge] #201907
01/23/09 02:20 PM
01/23/09 02:20 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Cab
At the moment there is 2-3/8" difference from my old 8-3/4, to me that seems too much, if i get 2" from swapping the tubes, the 3/8" is neither here or there.
best 60ft 1.36
Re: Dana questions [Re: deaks] #201908
01/23/09 03:18 PM
01/23/09 03:18 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Cab
Most all Mopar rearends utilize 1-3/8" pinion offset.Take your difference in demension and devide by 2 to get your true offset.
Re: Dana questions [Re: B G Racing] #201909
01/23/09 03:20 PM
01/23/09 03:20 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Cab
thats what it was, I knew it was something ending in 8
Re: Dana questions [Re: Quicktree] #201910
01/23/09 03:46 PM
01/23/09 03:46 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
To be right for your mopar the drivers side tube needs to be 1 3/8" longer than the pass side.
You have a bad situation with the drivers tube already shorter than the pass side. You'd have to shorten the pass side by 2 3/8" to get the pinion to proper offset. Finished width would end up at ~49 5/8"
Re: Dana questions [Re: Quicktree] #201911
01/23/09 03:47 PM
01/23/09 03:47 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
My A body 8-3/4 was definitely over 2" and it was stock width 57-1/2" wheel to wheel mount, maybe B and E bodies are different.
I dont follow your 2nd remark, surely the offset is the difference that one side is over the other from yoke centre to end.
best 60ft 1.36
Re: Dana questions [Re: deaks] #201912
01/23/09 04:58 PM
01/23/09 04:58 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Rob
The shorter tube is against the offset, so if the offset is swapped to the other side i will add 1" and lose another 1" off the other side, giving me my 2" offset.
best 60ft 1.36
Re: Dana questions [Re: deaks] #201913
01/23/09 05:21 PM
01/23/09 05:21 PM
RobX4406 Offline
RobX4406  Offline
however you do it, you need a drivers tube 1 3/8 longer than your pass tube to get the proper pinion location.
An 8.75 has equal length axles and the pinion offset is taken up by the carrier. Don't base anything you do with a dana off what the 8.75 would be, other than overall length.
Re: Dana questions [Re: RobX4406] #201914
01/23/09 06:59 PM
01/23/09 06:59 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
At the moment the pass side tube is 1-3/8" longer, that's why i'm cutting and swapping the ends side for side.
best 60ft 1.36
Re: Dana questions [Re: RobX4406] #201915
01/24/09 02:48 AM
01/24/09 02:48 AM
Eastern WA
P
ProStock1320 Offline
P
Eastern WA
Deaks, just to be sure, please confirm your left arm is the one hanging out of the window when you're in the driver's seat.
Re: Dana questions [Re: ProStock1320] #201916
01/24/09 02:53 AM
01/24/09 02:53 AM
Coeur d'Alene, ID
damnimcooltom Offline
Coeur d'Alene, ID
In England?
Re: Dana questions [Re: ProStock1320] #201917
01/24/09 03:03 AM
01/24/09 03:03 AM
RobX4406 Offline
RobX4406  Offline
Yeah my comments are for US cars not the righty drivers...
Re: Dana questions [Re: deaks] #201918
01/24/09 03:22 AM
01/24/09 03:22 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Measure from your frame rails to the center of your crankshaft, you should have a difference of 1 1/2". I checked my 67 barracuda and that is what I came up with.
Re: Dana questions [Re: RobX4406] #201919
01/24/09 08:57 AM
01/24/09 08:57 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
HOW do they shift left handed?...maybe because Im right handed,it seems realy weird and awkward using my left...and yes I do always use the right hand...here....speak to the hand....I had a left handed wife once..
Re: Dana questions [Re: smokinwoody] #201920
01/24/09 03:52 PM
01/24/09 03:52 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
To be honest i'm left handed, so shifting with the left is no problem, however, shifting my Dart, which incidently, was a manual for years, doesn't feel strange with the right hand either.
Going back to my axle, what is the minimum amount of mesh the shafts can get away with, before strength is compromised.
Mike
best 60ft 1.36
Re: Dana questions [Re: deaks] #201921
01/24/09 04:34 PM
01/24/09 04:34 PM
I think the stock axles have 1.5 inches or a liitle more The splines in most spools are around two inches per side and the axles stick out on the inside past the splines so more length is better just like the girls say, huh BG and Fred sorry, not trying to hijack this
