Dana questions
#201902
01/23/09 12:51 PM
01/23/09 12:51 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I've just bought a Dana for my Dart from a guy over here in England. It measures 52" wheel to wheel mounting, the problem i have, is that the yoke is right in the centre, the offset on my 8-3/4 is 2-3/8" . the drivers side tube is 1" shorter than the pass side, although the shaft is 1" longer. My plan is to cut a section from both tubes but the pass side, i will cut 1" longer and swap them side for side, giving me my 2" offset back. I am also thinking off making new front leaf mounts but a little longer to push the axle back a little, is this feasible and could there be any negatives. BTW, If you are reading this Cass, thanks for your time to quote me but the exchange rate has killed the pound against the dollar, making it ridiculously expensive to buy from the US at the moment.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: Dana questions
[Re: Quicktree]
#201904
01/23/09 02:04 PM
01/23/09 02:04 PM
deaks
robin hood country
Quicktree The Dana came from a tube chassis Road runner originally owned by Dave Shultz, i think the offset is more on A bodies than B and E. Can anyone tell me how critical is the offset and who has moved their axle back and what were the ramifications. Mike
Re: Dana questions
[Re: deaks]
#201906
01/23/09 02:15 PM
01/23/09 02:15 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
slide the rear end under the car and center the brakes in the wheel wells and take a look at the pinion location, if it is not what you want then fix it having the rear end housing offset to the right or left is like having it higher or lower than the transmission, angles are needed to make the U joints work, it really doesn't matter which way the angle differences are, up, down, left or right IMO
Re: Dana questions
[Re: Cab_Burge]
#201907
01/23/09 02:20 PM
01/23/09 02:20 PM
deaks
robin hood country
Cab At the moment there is 2-3/8" difference from my old 8-3/4, to me that seems too much, if i get 2" from swapping the tubes, the 3/8" is neither here or there.
Re: Dana questions
[Re: deaks]
#201908
01/23/09 03:18 PM
01/23/09 03:18 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Most all Mopar rearends utilize 1-3/8" pinion offset.Take your difference in demension and devide by 2 to get your true offset.
Re: Dana questions
[Re: B G Racing]
#201909
01/23/09 03:20 PM
01/23/09 03:20 PM
Quicktree
thats what it was, I knew it was something ending in 8
Re: Dana questions
[Re: Quicktree]
#201911
01/23/09 03:47 PM
01/23/09 03:47 PM
deaks
robin hood country
My A body 8-3/4 was definitely over 2" and it was stock width 57-1/2" wheel to wheel mount, maybe B and E bodies are different. I dont follow your 2nd remark, surely the offset is the difference that one side is over the other from yoke centre to end.
Re: Dana questions
[Re: deaks]
#201912
01/23/09 04:58 PM
01/23/09 04:58 PM
deaks
robin hood country
Rob The shorter tube is against the offset, so if the offset is swapped to the other side i will add 1" and lose another 1" off the other side, giving me my 2" offset.
Re: Dana questions
[Re: RobX4406]
#201914
01/23/09 06:59 PM
01/23/09 06:59 PM
deaks
robin hood country
At the moment the pass side tube is 1-3/8" longer, that's why i'm cutting and swapping the ends side for side.
Re: Dana questions
[Re: RobX4406]
#201915
01/24/09 02:48 AM
01/24/09 02:48 AM
Posts: 789 Eastern WA
ProStock1320
Eastern WA
however you do it, you need a drivers tube 1 3/8 longer than your pass tube to get the proper pinion location.
Deaks, just to be sure, please confirm your left arm is the one hanging out of the window when you're in the driver's seat.
Re: Dana questions
[Re: ProStock1320]
#201916
01/24/09 02:53 AM
01/24/09 02:53 AM
Posts: 190 Coeur d'Alene, ID
damnimcooltom
Coeur d'Alene, ID
In England?
Re: Dana questions
[Re: ProStock1320]
#201917
01/24/09 03:03 AM
01/24/09 03:03 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
Yeah my comments are for US cars not the righty drivers...
Re: Dana questions
[Re: RobX4406]
#201919
01/24/09 08:57 AM
01/24/09 08:57 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
HOW do they shift left handed?...maybe because Im right handed,it seems realy weird and awkward using my left...and yes I do always use the right hand...here....speak to the hand....I had a left handed wife once..
Re: Dana questions
[Re: smokinwoody]
#201920
01/24/09 03:52 PM
01/24/09 03:52 PM
deaks
robin hood country
To be honest i'm left handed, so shifting with the left is no problem, however, shifting my Dart, which incidently, was a manual for years, doesn't feel strange with the right hand either. Going back to my axle, what is the minimum amount of mesh the shafts can get away with, before strength is compromised. Mike
