70 Challenger Grill #2018050
02/23/16 02:07 PM
02/23/16 02:07 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
The grill on my 70 challenger R/T 440 Mag does not have any emblems on the grill. I would like to put challenger R/t on grill . . How where the fastened ? ?
thanks
Re: 70 Challenger Grill [Re: ct440rod] #2018072
02/23/16 02:52 PM
02/23/16 02:52 PM
Pennsylvania
W
WingedSixBBL Offline
W
Pennsylvania
I'll get a pic of mine & get it on here soon. They used 2 large (fender) washers & the speed nuts on the pegs. Or PM me your cell # & I'll send them direct to you. Well it turns out the washers I somehow thought I "remembered" aren't there after all. I get the pix uploaded later.
Re: 70 Challenger Grill [Re: ct440rod] #2018138
02/23/16 04:57 PM
02/23/16 04:57 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
So has to be some pretty long pegs . .
Re: 70 Challenger Grill [Re: ct440rod] #2018159
02/23/16 05:35 PM
02/23/16 05:35 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
Some more info here, I think the one on Kowalski's car seems about right!
https://board.moparts.org/ubbthreads/ubbt...-locations.html
Re: 70 Challenger Grill [Re: ct440rod] #2018254
02/23/16 07:57 PM
02/23/16 07:57 PM
Pennsylvania
W
W
Pennsylvania
Yep, pix sent, 3 minutes ago.......
Re: 70 Challenger Grill [Re: ct440rod] #2018261
02/23/16 08:08 PM
02/23/16 08:08 PM
Pennsylvania
W
W
Pennsylvania
Re: 70 Challenger Grill [Re: ct440rod] #2018273
02/23/16 08:39 PM
02/23/16 08:39 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
so where emblems cast with studs in them or glue on ? ?
Re: 70 Challenger Grill [Re: ct440rod] #2018298
02/23/16 08:55 PM
02/23/16 08:55 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Studs
Re: 70 Challenger Grill [Re: 5carguy] #2018343
02/23/16 09:35 PM
02/23/16 09:35 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
There are stick on "Challenger" emblems, think their original application was the trunklid. Original fender emblems had studs and were interchangable, BUT the grille emblem is a different unique emblem. Different thickness and plus it has studs.
jess
Yeah, it's hopped up to over 160...
Re: 70 Challenger Grill [Re: jt4406] #2018701
02/24/16 12:22 PM
02/24/16 12:22 PM
Pennsylvania
W
W
Pennsylvania
jess
The stick-ons are re-pops, my fender & decklid have 2 holes each for the pins to go through, with speed nuts on the backsides.
Re: 70 Challenger Grill [Re: WingedSixBBL] #2018784
02/24/16 03:11 PM
02/24/16 03:11 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
...seriously? Any way we could see a pic of this from backside of trunk lid? Not doubting you, just never seen it (or perhaps, noticed it) before.
jess
Re: 70 Challenger Grill [Re: jt4406] #2018803
02/24/16 03:34 PM
02/24/16 03:34 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
I would be skeptical that it came that way from the factory, but I guess anything is possible. My '70 Challenger has its original trunk lid and when we stripped it for paint there were no signs of it ever having holes for emblems.
Re: 70 Challenger Grill [Re: EV2RTSE] #2018869
02/24/16 05:03 PM
02/24/16 05:03 PM
Pennsylvania
W
W
Pennsylvania
My car came to me from Arizona via a friend in Meadville, PA, & it's hard to tell how many times it may have been painted in it's life. Someone may/must have drilled it prior to my ownership & I assumed it to be correct....... The last paint was an Earl Sheib special where they taped off the glass, lights & some of the grille & that "special, cover-all" paint......still a work in-progress........
Re: 70 Challenger Grill [Re: WingedSixBBL] #2019031
02/24/16 08:36 PM
02/24/16 08:36 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
Not all stick on are re-pops. I bought some in 76 that where stick on from dodge dealer
Re: 70 Challenger Grill [Re: WingedSixBBL] #2019037
02/24/16 08:50 PM
02/24/16 08:50 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
Challenger emblems should have 3 studs
Re: 70 Challenger Grill [Re: ct440rod] #2019306
02/25/16 05:47 AM
02/25/16 05:47 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
1970 Challenger R/T uses:
1 Challenger Grill Emblem with 3 long studs
1 R/T Grill Emblem with 2 long studs
2 Challenger Fender Emblems with 3 short studs
IF the car is stripe delete or has a tail stripe then 2 R/T Fender Emblems with 2 short studs
1 Challenger Deck lid Stick on Emblem
1 R/T Deck Lid Stick on Emblem
1971 Challenger R/T uses:
1 Dodge Grill Emblem
2 Challenger Fender Stick on Emblems
IF the car is stripe delete then 2 R/T Fender Stick on Emblems
1 Dodge Deck Lid Stick on Emblem
1 Challenger Tail Panel Emblem
Re: 70 Challenger Grill [Re: ct440rod] #2019395
02/25/16 12:10 PM
02/25/16 12:10 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Not that most people care, but since you are listing them...
72-74 Challenger(standard and Rallye)
1 Challenger grill emblem with 2 long studs
2 Challenger stick on emblems above side markers on upper quarter panel
Individual D O D G E letters in center of tail panel(much thicker then the hood letters and curved on the back side to match the curve of the tail panel)
Re: 70 Challenger Grill [Re: ct440rod] #2019756
02/25/16 08:59 PM
02/25/16 08:59 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
So anybody selling long stud emblems Challenger R/T
Re: 70 Challenger Grill [Re: ct440rod] #2019767
02/25/16 09:15 PM
02/25/16 09:15 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Yes, most repop dealers will have them. Classic Industries, yearone, etc.
Here's a link to one of my favorite dealers....
MegaParts
Re: 70 Challenger Grill [Re: ct440rod] #2019785
02/25/16 09:41 PM
02/25/16 09:41 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Dave @ Roseville Moparts has them,,,,
