Re: 98 5.9 Magnum won't run when wet out.....
[Re: QuickBpBp]
#2013430
02/16/16 09:26 PM
02/16/16 09:26 PM
RapidRobert
When I opened the hood the coil was all wet from water running down on it. It will start once it dries out but I need it to start even when its wet out!!! Any suggestions appreciated! Stop that waterfall
[Re: RapidRobert]
#2013438
02/16/16 09:34 PM
02/16/16 09:34 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
When I opened the hood the coil was all wet from water running down on it. It will start once it dries out but I need it to start even when its wet out!!! Any suggestions appreciated! Stop that waterfall If I could control the weather I would just get a new truck.....It gets parked up hill and rain was sideways today....
[Re: QuickBpBp]
#2013468
02/16/16 10:17 PM
02/16/16 10:17 PM
RapidRobert
what about laying a tarp in there when a rainy day is in the forecast?
[Re: QuickBpBp]
#2013475
02/16/16 10:24 PM
02/16/16 10:24 PM
Posts: 12,153 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Been there, done that. I used heavy zip lock baggies to cover the coil and distributor on my neighbor's beater truck having the same issue. Kept them dry.
Master, again and still
[Re: DusterDog]
#2013720
02/17/16 02:30 AM
02/17/16 02:30 AM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
I thought the ignition coil on a 5.9 truck engine was on the right front below the valve cover??
As a quick fix, try spraying some WD-40 on the cap, & wires.. I did the WD 40 trick and nothing.....Yes it is on the RH side by the belt tensioner. It was soaked when I opened the hood the distributor was dry. No "factory" parts are missing this just started a few weeks ago....
