Re: Why is a Dana stronger??
[Re: codfish]
#201150
01/22/09 05:26 PM
01/22/09 05:26 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
I'm thinking about selling my A-body rear, and buying a Dana 60. I know nothing about a Dana period. What makes it stronger exactly? I know it's heavier, but that's not an issue.
Oh, and do they have retainer plates like the 8 3/4, or c-clips?
Sorry for dumb questions.
codfish
Large ring gear,well placed pinion gear,strong,beefy center housing, large bearings,thicker axle tubes and plentiful and cheap(3/4 ton trucks) Retainers like 8-3/4
[Re: B G Racing]
#201151
01/22/09 05:43 PM
01/22/09 05:43 PM
After you blow up several 8 3/4 units ( which have a place in racing just not with big blocks and slicks ) you will have spent enough to buy a Dana. Buy the Dana , race it your entire career the take it out and sell it. If you sell all your 8 3/4 suregrips and gears first then buy the Dana --you will actually wind up ahead of the game--WAY ahead. Remember that every time you kill a rear or drive shaft etc you also kill an over running clutch and or converter If you have a small block and already have 8 3/4 stuff go for it--otherwise you are CRAZY not to go Dana 60 in a HOSS! This is not my two cents worth this is actual scientific conclusion from extensive testing ( I mean $$ spending )
[Re: ]
#201153
01/22/09 06:27 PM
01/22/09 06:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
WOW, I guess I better sell my 8 3/4 now... I dont want to be called CRAZY. Have you seen any diggers with the 8 3/4. IMO(which doesnt mean much) its the weight that kills a 8 3/4 and in the extensive testing I'm sure that came up ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#201154
01/22/09 06:37 PM
01/22/09 06:37 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
Well I have a full bodied 68 Dart, with a stroked 440. 727 with a manual valve body, and no transbrake. The 8 3/4" has been in there for 5 years now, with three or four races each season, but behind a mild 360, and Hoosier Quick Times. Of course it has held up just fine. Now that I have the new powerplant in, I'm gonna probably use some 29 or 30 inch tall slicks, maybe 10 or 11 inches wide. Just don't want to hurt the new trans by blowing up the rear. Paranoid maybe ![](/ubbthreads/images/graemlins/shruggy.gif) Anyone dealt with DTS before? ![](http://i144.photobucket.com/albums/r174/codfish1_bucket/new3.jpg) codfish
[Re: codfish]
#201159
01/23/09 03:19 AM
01/23/09 03:19 AM
Posts: 43,308 Bend,OR USA
Cab_Burge
The Dana 60 came in several different versions in the Mopar production cars, the main differences was the axle size and spline count on the axles. The 1970-71 cars with stock Dana 60 came with 35 spline axles that are a lot bigger in diameter than any other production rear end installed in production cars. The cutom made race versions that Strange Engr. and almost everyone else sells today come with the 35 spline axles, as already said the pinion shaft is thicker, the ring gear diameter is bigger and the cast steel housing and pressed in large diameter axle tubes are strong ![](/ubbthreads/images/graemlins/thumbs.gif) pretty good stuff ![](/ubbthreads/images/graemlins/bow.gif) Way better than any stock Ford nine inch beef up, ![](/ubbthreads/images/graemlins/puke.gif) IMO ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: ]
#201160
01/23/09 09:29 AM
01/23/09 09:29 AM
Posts: 146 landover, md
b1n02cuda
landover, md
[After you blow up several 8 3/4 units ( which have a place in racing just not with big blocks and slicks ) you will have spent enough to buy a Dana. Buy the Dana , race it your entire career the take it out and sell it./quote]
![](/ubbthreads/images/graemlins/2516024-blahblah.gif)
I wish you 8 3/4 bashers would just soon get a life, or maybe just learn how to set them up. Every part has a limit and I know of many many many, did I say many, 3000lb plus cars with slicks going very quick with 8 3/4 rears without any issues. For your setup, an 8 3/4 will be fine... Until you go consistant 8 second passes, or consistant sub 1.2 60ft times, you got nothing to worry about. Just buy new stuff, and go have fun. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: codfish]
#201162
01/23/09 12:34 PM
01/23/09 12:34 PM
Posts: 5,080 organ
maximum entropy
organ
every time i'm under my car, i spend time gazing at mr. 60, mr. dana 60, with awe and admiration. he's HUGE. he's indefatigable. he's a little overweight, but only by about 15 pounds. he'll always be there for me. and that's why he's better.
[Re: Thumperdart]
#201165
01/23/09 01:29 PM
01/23/09 01:29 PM
Quicktree
Well said.........maybe the guys blowin em up are setting em up wrong or were set up wrong for them. Come on,"my 11 sec car went through 10 8 3/4`s in one year" gimme a break.
or maybe we know how to put enough power to the ground to snap them like a pretzel yea you guys are probably the only ones on the planet who know how to set one up ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: Quicktree]
#201166
01/24/09 01:50 AM
01/24/09 01:50 AM
b1n02cuda
landover, md
Oh Great One; ![](/ubbthreads/images/graemlins/bow.gif) Why do you bother posting about this? You don't even have a car. And what in the crap do you know about putting power to the ground? You drive a friends 1000 lb dragster with a steam roller tire and all the weight over the rear axle. How hard is that to make hook. OOOOOOOOHHHHHHHHHHH If you could read, I said I know of many cars going eights and nines at over 3000 lbs. So Oh Great One, you think these guys don't know how to put power to the ground? And most of these guys I know are small tire guys that probably have better 60 ft times than that thing you drive. You should wear a bowtie, because you fit right in with that croud. ![](/ubbthreads/images/graemlins/puke.gif)
[Re: Thumperdart]
#201168
01/24/09 02:58 AM
01/24/09 02:58 AM
Quicktree
Damn, I`m not gonna touch that but I will say this Quick..........1.36 60f and 6.26 aint too shabby for a 3150lb street car on dot`s at an ok track.
add 500lbs and come back and tell us how that works ![](/ubbthreads/images/graemlins/laugh2.gif)
