shifter question #2010371
02/12/16 09:43 AM
02/12/16 09:43 AM
Shelby Twp. Michigan
demonman Offline OP
demonman  Offline OP
I have a 1966 barracuda 273 4spd car all original. It has the stock lock out reverse style shifter(lock out is non functional and is very hard to find gears). Well I would like to go with a hurst set up. Is this possible with this style/year trans?
If so are there any tricks/tips/part numbers I should know?
Any help would be appreciated.
1968 Barracuda project.
R.I.P. Gary"UNLAWFL"Davis You are missed.
Re: shifter question [Re: demonman] #2010376
02/12/16 10:41 AM
02/12/16 10:41 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
http://www.brewersperformance.com/products.asp?cat=51
Call Brewers for advice. They have setups for console and no console '66s.
Re: shifter question [Re: Pynzo] #2010381
02/12/16 10:47 AM
02/12/16 10:47 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
You can get a Hurst mechanism and use your current handle to make it look stock if you want to. work
JB Rhinehart, Realist
A-Body's RULE!
Re: shifter question [Re: Rhinodart] #2010470
02/12/16 02:37 PM
02/12/16 02:37 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I ran a Hurst Super Shifter many years ago in my 66 Dart and it worked and fit fine. Course I did not have a console in it. Ron
Re: shifter question [Re: Rhinodart] #2010497
02/12/16 03:21 PM
02/12/16 03:21 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
http://www.brewersperformance.com/products.asp?cat=50
