Page 2 of 3 1 2 3
Re: Low Deck Hemi [Re: evenflow] #2010245
02/12/16 12:32 AM
02/12/16 12:32 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
https://board.moparts.org/ubbthreads/ubbt...deck%20hemi.jpg
Back around 1974 I was at Barnett Race Cars in Atlanta with a buddy. One of the Barnett's (don't remember now which one) was welding chrome moly tubes into a 400 block and turning it into a Hemi block just like the picture above. the pistons were considerably shorter and he used a shorter stroke with the long rods to get a 396 cu inch Hemi for the lighter car and lighter rotating assembly.
Jerry
Old Geezer Racing
Re: Low Deck Hemi [Re: Dragula] #2010254
02/12/16 12:41 AM
02/12/16 12:41 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Dave Koffel and Wally Dyck ran a B dragster with a 383 and Hemi heads in Comp in the late 80's I believe it was the #1 qualifier At Indy. This was right before the B-1 head era. I believe a friend of mine still has the block and heads.
Doug
Re: Low Deck Hemi [Re: Dragula] #2010270
02/12/16 12:57 AM
02/12/16 12:57 AM
Chattanooga, TN
KDY Offline
KDY  Offline
Chattanooga, TN
So what's the fesability of building one of these?
Seems like the downfall is a heavy dome piston, custom rods and figuring out an intake.
Re: Low Deck Hemi [Re: evenflow] #2010386
02/12/16 10:59 AM
02/12/16 10:59 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Mike had Tom Hanners old parts. 400 block. The deck on the block in the old pics was decked quite a bit. Look at where the water pump bolt holes are in relation to the deck. I have a 9.700 deck KB block that came from the B1 TS pro stock era. Building a 484 B1 twin turbo motor out of it.
Re: Low Deck Hemi [Re: KDY] #2011193
02/13/16 05:17 PM
02/13/16 05:17 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Would be easier due to that Stage V wedge pattern head still being available.
The Super Stock Hemi pistons being run today are in the lower 500 gram range, so piston weight wouldn't be an big issue. BBC rods are plentiful, and a std. deck intake can be modified (like seen in the earlier pics).
Re: Low Deck Hemi [Re: Dragula] #2011206
02/13/16 05:41 PM
02/13/16 05:41 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Funny story I just remembered about Hagen - the NHRA engine set back rule was that the front spark plug hole centerline could not be further back than the front spindle centerline. NHRA thought that the motor was set back too far - so off comes the valve cover, flip the plug hole cover and tube 180 degrees, put the spark plug in the other farther forward hole and back together.
Re: Low Deck Hemi [Re: Dragula] #2018049
02/23/16 02:04 PM
02/23/16 02:04 PM
an8sec70cuda Offline
http://www.ebay.com/itm/Stage-Five-engin...76#ht_38wt_1099
Didn't know they made these. Stage V low deck hemi inline dual four manifold.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Low Deck Hemi [Re: an8sec70cuda] #2018122
02/23/16 04:23 PM
02/23/16 04:23 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Stage V must have made a run of the wedge pattern blocks? I wonder if the lack of new hemi blocks has anything to do with it , assuming they did ?
The picture of the block Joel posted also shows half round stock welded in where the Exh push rod intrude into the edge of the deck.
I wonder what they did to the main caps ?
Re: Low Deck Hemi [Re: KDY] #2018131
02/23/16 04:41 PM
02/23/16 04:41 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Charlie Malyuke's
[/URL]
I wonder why the oil pan rail is milled on the drivers side? Center image.
Re: Low Deck Hemi [Re: Dragula] #2018132
02/23/16 04:45 PM
02/23/16 04:45 PM
Probably to get rid of the lip...enhancing oil drainback. Also slightly helping w/ windage too I'd guess.
CHIP
Re: Low Deck Hemi [Re: Dragula] #2018622
02/24/16 05:16 AM
02/24/16 05:16 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: Low Deck Hemi [Re: evenflow] #3175225
09/14/23 06:46 PM
09/14/23 06:46 PM
neche, ND
526 Offline
526  Offline
neche, ND
I have one that was sold t my home town t Wally Dyck of Winnipeg Manitoba Canada raced fr many years with it fr mopar.I have the heads and crank too. 1966 K alum hemi heads highly ported by Mullins and flowed 420 int and 260 exh. Email ur storys and pics t me Blown526@icloud.com thx
Re: Low Deck Hemi [Re: SCATPACK 1] #3175228
09/14/23 06:51 PM
09/14/23 06:51 PM
neche, ND
526 Offline
526  Offline
neche, ND
I have a 400 low deck original hemi block that wally dyck bought and ran fr several years.
Re: Low Deck Hemi [Re: evenflow] #3175229
09/14/23 06:55 PM
09/14/23 06:55 PM
neche, ND
526 Offline
526  Offline
neche, ND
I have one still thx
Re: Low Deck Hemi [Re: 526] #3175235
09/14/23 07:35 PM
09/14/23 07:35 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
A 7 year old thread has been brought back to life?!?!
Alan Jones
Re: Low Deck Hemi [Re: evenflow] #3175238
09/14/23 07:49 PM
09/14/23 07:49 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Originally Posted by evenflow
I know of one brazed block floating around that has had .300 taken off the deck. Mike Radnis used to run that set up in one of his old cars. Not sure if he is a member.
Mike had a 400 block. His brother Tim and he also had some of Hanner's engine parts. Unfortunately Mike passed from Cancer in 2021.
Re: Low Deck Hemi [Re: fbs63] #3175333
09/15/23 10:56 AM
09/15/23 10:56 AM
NY
B1duster Offline
B1duster  Offline
NY
Any of you remember a magazine article from like 30yrs ago where a guy was building low deck hemis by machining flats in the valley and using epoxy and bolts to add blocks for the inner studs ? I’m thinking his name was Holt ???
Re: Low Deck Hemi [Re: LA360] #3175537
09/16/23 06:45 AM
09/16/23 06:45 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
....and????
petty
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Low Deck Hemi [Re: Dragula] #3175597
09/16/23 11:59 AM
09/16/23 11:59 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Was the last Mopar Wing Car in 1971 at Daytona a destroked 305 Hemi or a SBM?
Since Min weight back then was 3600? lbs, weight was not much of an issue.
Re: Low Deck Hemi [Re: jcc] #3175758
09/17/23 12:43 AM
09/17/23 12:43 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
I'm pretty sure the Dick Brooks Daytona ran a Keith Black prepped 305 (destroked 340) engine. The smallest Hemi I remember was the 366 Hemi with the 3.21" stroke crank and stupid long rods (7.3"). They were more successful in the Mopar Missile with the D5 heads as I recall.
Floyd Lippencott IV
Page 2 of 3 1 2 3
