removing window tintt #2007351
02/07/16 02:16 PM
02/07/16 02:16 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Ok so I need to remove some window tint. The side glass wasn't too terrible, however the rear window is a PITA. It has rear defrost so I cannot use a razor. I have tried the plastic bag w/ 409 trick, however it is 40* here and that didn't work even with a hair dryer going, heater going and defrost on...
Is there any chemical I can use? I saw a guy used aircraft stripper and a plastic blade....
Coming soon!!!!
Re: removing window tintt [Re: Mr.Yuck] #2007413
02/07/16 04:10 PM
02/07/16 04:10 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I have the same dilemma with a used car I bought my wife in FL. a couple of years ago. Sides & rear window on a 300M were all tinted. I peeled the driver's door glass tint & used glass cleaner & razor blade with the door panel still on - THAT was a PITA! I didn't even do the others yet. As far as the back glass, I think I'll get a good used glass from a junkyard & just replace it with that. Peel it & clean it? NO WAY!
Re: removing window tintt [Re: Mr.Yuck] #2007590
02/07/16 10:01 PM
02/07/16 10:01 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Impossible to remove without hurting a few lines on the defroster..i used carb cleaner on a rag to get the glue off..
Re: removing window tintt [Re: AARCONV] #2007621
02/07/16 10:58 PM
02/07/16 10:58 PM
santa anna, Tx.
charles6970 Offline
charles6970  Offline
santa anna, Tx.
use a heat gun, "hair drier" when peeling off the old tint.
Re: removing window tintt [Re: Mr.Yuck] #2007671
02/08/16 12:22 AM
02/08/16 12:22 AM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
ammonia is the solvent for window tint. Don't know if I would go %100 ammonia out of the gate, maybe cut it down to %25 and see what happens and move up from there.
Re: removing window tintt [Re: it's Bob] #2007785
02/08/16 03:14 AM
02/08/16 03:14 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
My detail shop friend said spray ammonia on the tint and cover with black plastic bag and put in sun. Maybe that wont work at 40 degrees. I've used a clothing steamer with success in the past. Just work slow with the hot steam and it peels off in sheets.
Re: removing window tintt [Re: Mr.Yuck] #2007867
02/08/16 12:14 PM
02/08/16 12:14 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Use a steamer like those designed for getting wrinkles out of your (or your wife's) blouse.
It'll peel right off without hurting the defroster lines.
- Stu Harmon
Re: removing window tintt [Re: Mr.Yuck] #2007895
02/08/16 01:14 PM
02/08/16 01:14 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Yeah I tried the bag thing, no good in the cold, I tried the aircraft stripper, nothing. I'll try the steamer. They are cheap enough. WHY do people need the window so dark?
Re: removing window tintt [Re: Mr.Yuck] #2012127
02/14/16 11:48 PM
02/14/16 11:48 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I wondered the same thing and peeled the tint of this truck, which I could NOT back up at night time. I found 2 layers on top of each other.
As for the defroster lines. I'm also looking for a solution.
Re: removing window tintt [Re: Magnum] #2012456
02/15/16 03:03 PM
02/15/16 03:03 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Soak it good with windex and work it off with a heat gun or a hot hair dryer, it works. Windex is just diluted ammonia but high concentrate ammonia is too strong to breath the fumes so I wouldn't recommend it without a respirator. It can form hydrochloric acid with the water in your lungs, not worth the risk
If you catch the corner just right just keep spraying the windex to the underside as you pull it off at about a 60 degree angle to the glass.... it should pull off in sheets nice and clean.
Same thing for removing decals
WIZE
In Car:
Re: removing window tintt [Re: feets] #2012474
02/15/16 03:25 PM
02/15/16 03:25 PM
Middle TN
da50r Offline
da50r  Offline
Middle TN
This....
Re: removing window tintt [Re: Magnum] #2012568
02/15/16 05:40 PM
02/15/16 05:40 PM
Long Island, NY
shocktrp Offline
shocktrp  Offline
Long Island, NY
Well I have a solution for backing up at night;
http://www.amazon.com/gp/product/B00QTGXYIE
It is by no means a great camera, but it is enough to see what is directly behind you & it uses your license plate screws.
You can wire it as a stand alone & just plug it into your cigarette lighter when you need to use it.
Re: removing window tintt [Re: Mr.Yuck] #2013114
02/16/16 02:13 PM
02/16/16 02:13 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I used the steamer. worked pretty good. I just have to get some glue off. This thing had 3 layers of tint. Anybody have the best way to remove the glue? WD doesn't work, goof-of doesn't work. said car. 03 CV Sport.
Re: removing window tintt [Re: Mr.Yuck] #2031977
03/15/16 11:23 PM
03/15/16 11:23 PM
Magnum Offline
Magnum  Offline
I've got an update. Not a good update, just an update.
There is hours into this rear window tint glue removal.
The tint came off in one complete sheet with the help of a heat gun.
The glue is it's own problem. I'd say 75% of the glue stayed with the tint but the %25 left on my rear window with defroster lines is work.
Using a plastic razor blade and Goo Gone I've accepted the fact progress is being made, just not much of it.
Been using the blade to get the big areas scrapped down but close to the defroster lines it's just spray and wipe and repeat 10x's. Even with the glue gone there is a oily film which needs the help of Windex.
Re: removing window tintt [Re: Magnum] #2032262
03/16/16 11:17 AM
03/16/16 11:17 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I used a clothes steamer. Worked pretty well. The lower corners are still there but I don't have to look out them. I used window cleaner with ammonia let it soak in added some more to get the glue off. Not perfect but I can see thru it now.
