are 71 b-body danas rare #2000442
01/28/16 02:26 PM
01/28/16 02:26 PM
central il.
second 70 Online content OP
second 70  Online Content OP
central il.
I was working on my 70 cuda the other day and found the codes on my danas axle tubes. It is 9-15-OA1 9-15-70 B7 603222-1 which makes it a lynch rd. b-body 3:54? The perches must have been moved because these are longer than an e-body.
I just didn't know how rare these danas are?
Re: are 71 b-body danas rare [Re: second 70] #2000469
01/28/16 03:14 PM
01/28/16 03:14 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
They are fairly hard to find, but do pop up regularly. The correct e-body Dana is more desirable though.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: are 71 b-body danas rare [Re: second 70] #2000661
01/28/16 07:59 PM
01/28/16 07:59 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Hard to find and fairly rare. Still anything E Body brings a premium
Re: are 71 b-body danas rare [Re: second 70] #2001168
01/29/16 02:22 PM
01/29/16 02:22 PM
central il.
central il.
I was getting ready to change it to a 4:10 and since my car is non-numbers matching I thought I would check to see how rare they are before I did incase someone with a #s matching car really needed it.
Re: are 71 b-body danas rare [Re: second 70] #2001196
01/29/16 03:03 PM
01/29/16 03:03 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What makes you think it's a Lynch Rd. rear end ?
Re: are 71 b-body danas rare [Re: second 70] #2001198
01/29/16 03:05 PM
01/29/16 03:05 PM
JohnRR Offline
JohnRR  Offline
It's going to cost you more to replace the rear with an E body rear, or get a rear from a place like strange, because the perches have been moved so it's going to sell for less than one that has not been dicked with.
It's set up in your car, change the gears .
Re: are 71 b-body danas rare [Re: JohnRR] #2001202
01/29/16 03:08 PM
01/29/16 03:08 PM
central il.
central il.
The OA1 in the first date?
Re: are 71 b-body danas rare [Re: JohnRR] #2001547
01/29/16 11:07 PM
01/29/16 11:07 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I would agree. Just use it or offer it up as trade bait.
Re: are 71 b-body danas rare [Re: second 70] #2002607
01/31/16 01:01 PM
01/31/16 01:01 PM
central il.
central il.
Thanks for all the replies. I'll just change the gear and be happy with the lack of extra work.
Re: are 71 b-body danas rare [Re: second 70] #2004012
02/02/16 10:39 AM
02/02/16 10:39 AM
WV
Little Detroit Offline
WV
how much you want for the 71 dana??pm me here
Re: are 71 b-body danas rare [Re: JohnRR] #2004049
02/02/16 12:27 PM
02/02/16 12:27 PM
muskegon MI
v cummins Offline
v cummins  Offline
muskegon MI
popcorn
Re: are 71 b-body danas rare [Re: v cummins] #2004129
02/02/16 02:46 PM
02/02/16 02:46 PM
central il.
central il.
In the date is says it was 9-15-0 A1 A is lynch road. 9-15-70 B7 just thought the A meant lynch. Not really sure.
Re: are 71 b-body danas rare [Re: second 70] #2004266
02/02/16 05:57 PM
02/02/16 05:57 PM
muskegon MI
v cummins Offline
v cummins  Offline
muskegon MI
Its what shift that operation took place
Re: are 71 b-body danas rare [Re: v cummins] #2004321
02/02/16 07:20 PM
02/02/16 07:20 PM
central il.
central il.
So does that mean A-lynch Rd. 1- 1st shift then what does the B7 mean?
Re: are 71 b-body danas rare [Re: second 70] #2004367
02/02/16 08:41 PM
02/02/16 08:41 PM
muskegon MI
v cummins Offline
v cummins  Offline
muskegon MI
A is first shift. 1 is line 1
B is second shift. 7 is line 7
If A was lynch Rd., that means the B meant that they changed their mind and went to Hamtramck.
Re: are 71 b-body danas rare [Re: v cummins] #2004390
02/02/16 09:17 PM
02/02/16 09:17 PM
central il.
central il.
thanks for the info. I couldn't figure out why it was stamped with 2 different 9-15-70 dates.
