Thermostat Housing Leak after Thermostat Replacement
#1996916
01/23/16 12:27 PM
01/23/16 12:27 PM
Posts: 364 US
f2502011
US
Had too cool of a thermostat (160) pulled it and replaced with a 180 and now the housing is leaking. Used new gasket, thin film of thermostat housing sealer, torqued bolts to spec and it's leaking. What did I do wrong and how can I fix?
1970 EK2 T/A 727
Re: Thermostat Housing Leak after Thermostat Replacement
[Re: f2502011]
#1996918
01/23/16 12:28 PM
01/23/16 12:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
what engine?
What housing?
[Re: f2502011]
#1996941
01/23/16 01:04 PM
01/23/16 01:04 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Is it the right stat.There are 2 one large one small.Is it leaking or seeping.Big difference.The surfaces must be real clean.I use a new gasket and a thin film of brown Permatex.Never had a leak and I did a bunch at home and the shop.Rocky
Chrysler Firepower
[Re: therocks]
#1996948
01/23/16 01:13 PM
01/23/16 01:13 PM
Posts: 364 US
f2502011
US
Is it the right stat.There are 2 one large one small.Is it leaking or seeping.Big difference.The surfaces must be real clean.I use a new gasket and a thin film of brown Permatex.Never had a leak and I did a bunch at home and the shop.Rocky It's the large one and it's just like the one that came out except it's a 180 instead of a 160. Was really clean and dry. It's seeping out the back middle of the housing trickling down the passenger side of intake and accumulating in the front right bolt crevice. I'm going to pull it back off and use indian head shellac this time.
1970 EK2 T/A 727
[Re: f2502011]
#1996982
01/23/16 01:58 PM
01/23/16 01:58 PM
therocks
Niles , Ohio
Check the housing.They can crack pretty easy at times.That and Ive seen whee the stat shifts a bit and keeps it from sealing.Rocky
Chrysler Firepower
[Re: f2502011]
#1996991
01/23/16 02:05 PM
01/23/16 02:05 PM
RapidRobert
I've had more trouble with leaking stat housings than anything else I've ever dealt with. Get a new WIDE gasket. Wouldn't hurt to drawfile the housing and the flange it sets on (put a rag inside to catch the shavings). with it installed you should be able to reach in the neck & grab the "arch" & move it a bit which tells you the stat is in the recess tho I dont see that as an issue here but I do check that. On one I had to use "the right stuff" ON a gasket to get it to seal & that is a gasket maker itself in a can, just a real light coat to get a good seal. Still ain't figured out why that piece is so problematic as you'd think it'd be the exact opposite considering its nature. I think using or cutting a new wide gasket is the key & some cement of course
[Re: therocks]
#1996998
01/23/16 02:09 PM
01/23/16 02:09 PM
Supercuda
About to go away
About to go away
up yours
Run a draw file across the housing to see if it's flat as well. If you need a replacement, stay away from chromed ones, they don't last.
[Re: mopars4ever]
#1997662
01/24/16 02:06 PM
01/24/16 02:06 PM
RapidRobert
I used the NAPA cast iron one & the width of the flange was thinner than I woulda liked but it did seal with a very thin/even coat of "the right stuff" gasket maker on a cut (wider than OE) piece of gasket material (+ drawfiling both). the nipple has no raised hose barb so I ground one as this is a high psi app & its thick enough there to easily do so. EDIT I think the narrow flanges and slight warpage is the problem cause. If one of those chrome ones has a wide flange (& the barb) I'd like to try one & sand off the chrome/get it flat
[Re: f2502011]
#1997710
01/24/16 03:36 PM
01/24/16 03:36 PM
Posts: 364 US
f2502011
US
Appreciate all the input and suggestions. Thing is, it sealed before not sure why it wouldn't again if I can get it done right. I've reinstalled the oem one and used Indian head shellac. We'll see. I do wonder how long I should let it dry?
1970 EK2 T/A 727
[Re: screamindriver]
#2000378
01/28/16 12:44 PM
01/28/16 12:44 PM
Posts: 360 Ohio
shorthorse
Ohio
[/quote] That's a good housing.. I've used the O ring style and have found that over time even those will weep from expansion/contraction..Now if I use that style I add a little RVT to help the sealing duties ... [/quote] I could see that happening but mine are on race cars and they don't get the amount of running time that a street car would have. I know my first one has to be about 8-10 years old and is still holding. I can see where the o-ring could get hard and brittle. They sell replacement o-rings. Have you ever tried that?
[Re: f2502011]
#2000506
01/28/16 03:50 PM
01/28/16 03:50 PM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
Appreciate all the input and suggestions. Thing is, it sealed before not sure why it wouldn't again if I can get it done right. I've reinstalled the oem one and used Indian head shellac. We'll see. I do wonder how long I should let it dry? Did you check to make sure it was flat or did you just ignore that suggestion? They do warp over time and you can tighten the bolts all you want, if it's cupped it will not seal. Why did it seal before ?? thicker gasket, more sealer that was allowed to fully cure before coolant being added again ?
