Solid roller lifters for big block...
#1996492
01/22/16 07:01 PM
01/22/16 07:01 PM
dartman366
Mt. Vernon, Ohio
..which ones you guys running, I have been looking them over and like the bushing style as opposed to the needle bearing's,has anyone had any luck with Howards or MRL brands??
Re: Solid roller lifters for big block...
[Re: rebel]
#1996530
01/22/16 08:03 PM
01/22/16 08:03 PM
Posts: 1,030 ohio
67mprfan
ohio
I'm using comps with about 3-4 years now no problems yet
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: blowndart]
#1996622
01/22/16 10:10 PM
01/22/16 10:10 PM
Thumperdart
State of confusion
Isky Red zones. No problems so far. One of the best right there and had em installed and ran em but low oil pressure was an issue in un-bushed block so Isky sent me their solid body lifters and after several years/miles and one rebuild, we`re golden..........
[Re: Stanton]
#1996642
01/22/16 10:31 PM
01/22/16 10:31 PM
dartman366
Mt. Vernon, Ohio
Cranes. For the life of me I can't understand why the one's with bushings cost more than the rollers. That makes no sense to me either.
[Re: dartman366]
#1996646
01/22/16 10:42 PM
01/22/16 10:42 PM
crabman173
crabman173
I have the Steens in stock----USA made--super quality--good as Comps if not way better $375 set yea you can't Google them--they keep low profile and just keep on making some of the best private label parts ever-- Good to 650 open easy as pie want 750 and up on open--( you lifter killer you) go with some bushed Morels and pay out the y8ing yang OR...run reasonable lower pressures than are asked for by the crazy computer designed lobe crowd--run a reasonable lobe and get by with less $$$ lifters or...pay $900 for lifters run 1000 lbs open and still loose that bracket race round by .003 These days the newest lobes "require" stupid spring pressures you are probably not in a COMP Eliminator class turning 11K RPM so ... Keep it reasonable--keep it in one piece--keep $$ under control Stay away from Johnsons ( labeled as many names you know) Steens are way cool lifters for the dough
[Re: ]
#1996663
01/22/16 11:00 PM
01/22/16 11:00 PM
Posts: 4,457 Washington
madscientist
Washington
I have the Steens in stock----USA made--super quality--good as Comps if not way better $375 set yea you can't Google them--they keep low profile and just keep on making some of the best private label parts ever-- Good to 650 open easy as pie want 750 and up on open--( you lifter killer you) go with some bushed Morels and pay out the y8ing yang OR...run reasonable lower pressures than are asked for by the crazy computer designed lobe crowd--run a reasonable lobe and get by with less $$$ lifters or...pay $900 for lifters run 1000 lbs open and still loose that bracket race round by .003 These days the newest lobes "require" stupid spring pressures you are probably not in a COMP Eliminator class turning 11K RPM so ... Keep it reasonable--keep it in one piece--keep $$ under control Stay away from Johnsons ( labeled as many names you know) Steens are way cool lifters for the dough What diameter is the lifter wheen on the Steens??
[Re: ]
#1996665
01/22/16 11:05 PM
01/22/16 11:05 PM
Posts: 4,647 aotearoa
rebel
aotearoa
I have the Steens in stock----USA made--super quality--good as Comps if not way better $375 set yea you can't Google them--they keep low profile and just keep on making some of the best private label parts ever-- Good to 650 open easy as pie want 750 and up on open--( you lifter killer you) go with some bushed Morels and pay out the y8ing yang OR...run reasonable lower pressures than are asked for by the crazy computer designed lobe crowd--run a reasonable lobe and get by with less $$$ lifters or...pay $900 for lifters run 1000 lbs open and still loose that bracket race round by .003 These days the newest lobes "require" stupid spring pressures you are probably not in a COMP Eliminator class turning 11K RPM so ... Keep it reasonable--keep it in one piece--keep $$ under control Stay away from Johnsons ( labeled as many names you know) Steens are way cool lifters for the dough do they make offset lifters?
[Re: dartman366]
#1996706
01/22/16 11:54 PM
01/22/16 11:54 PM
crabman173
crabman173
no offsets I think wheel is .750 have to check but feel sure that is what they are
[Re: dartman366]
#1996810
01/23/16 02:25 AM
01/23/16 02:25 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
$900. . I got some Jesel tool steel tie bar lifters, check the price out on those !!!!
[Re: Jerry Kathe]
#1996894
01/23/16 11:50 AM
01/23/16 11:50 AM
crabman173
crabman173
FWIW Bushed lifters NEED OIL all recent improvements to bushed units is in "oil to bushing" dept Every sort of groove/hole/ditch/passage is being employed BEST ADVICE IS--keep using a normal sane lobe not some stupid -may make another 5 HP computer designed crap lobe that requires giant spring pressure
and...to help prevent "skidding" we have always bead blasted roller lobes adding a "tooth" to them --after tear down it always looks better on the ramps after this easy cheap band-aid before we did this ramps would show "skidding" This is in circle track applications---it can't hurt IMO
[Re: camastomcat]
#1996929
01/23/16 12:48 PM
01/23/16 12:48 PM
crabman173
crabman173
Well, I've been running bushed Crower bushed lifters for 3 years. My spring pressures are 450 on the seat, 1200 open. My 55mm roller cam is close to an inch. So far I have had no failures and that's what it takes to make a predator engine run. I haven't run 650 open pressures in 20 years but if I did, the needle bearing Morel or Comps would be fine. I had problems with those when I got into the 750-800 lbs range, but I have friends that run the Manley 221424 springs and standard offset Comps and they get 200 passes without a problem. I really like the bushed lifters as if they do start to wear out, they don't deposit extremely hard little needle bearings somewhere in your engine. JMO I agree!! Just figure most guys here are bracket racers and should stay in the "safe" lane lobe wise but cam makers tend act like we all have an engine like yours and get regular guys off in the weeds with crazy high pressures On the dyno you can really see the diff in lobes and what it takes to control the newest lobes--it is relaxing to run an "old" style lobe that can be controlled with lower pressures--they can still make big beautiful HP in most stock block combos The proof of all this conversation is the trend of everyone having lifter issues and crushing out the needles--the conversation always starts out--"well..my cam grinder said I need 1000 open" then " I got 20 runs and wheel fell off of lifters" always comes back to the "new" cam they started using I miss the days of the old .590 solid in a 440 and a J converter--:)
