Page 1 of 3 1 2 3
Solid roller lifters for big block... #1996492
01/22/16 07:01 PM
01/22/16 07:01 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
..which ones you guys running, I have been looking them over and like the bushing style as opposed to the needle bearing's,has anyone had any luck with Howards or MRL brands??
Re: Solid roller lifters for big block... [Re: dartman366] #1996520
01/22/16 07:47 PM
01/22/16 07:47 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I was going to buy MRL myself until my racing buddy had a major failure with them. The roller fell off & destroyed a lobe on his cam. I'm using comp cams offset on both of my motors. Never had a failure that was related to the rollers.
Re: Solid roller lifters for big block... [Re: rebel] #1996530
01/22/16 08:03 PM
01/22/16 08:03 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I'm using comps with about 3-4 years now no problems yet
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Solid roller lifters for big block... [Re: dartman366] #1996533
01/22/16 08:11 PM
01/22/16 08:11 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Cranes. For the life of me I can't understand why the one's with bushings cost more than the rollers.
Re: Solid roller lifters for big block... [Re: dartman366] #1996615
01/22/16 09:56 PM
01/22/16 09:56 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
Isky Red zones. No problems so far.
Re: Solid roller lifters for big block... [Re: blowndart] #1996622
01/22/16 10:10 PM
01/22/16 10:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
One of the best right there and had em installed and ran em but low oil pressure was an issue in un-bushed block so Isky sent me their solid body lifters and after several years/miles and one rebuild, we`re golden.......... thumbs
Re: Solid roller lifters for big block... [Re: Stanton] #1996642
01/22/16 10:31 PM
01/22/16 10:31 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
That makes no sense to me either. shruggy
Re: Solid roller lifters for big block... [Re: dartman366] #1996646
01/22/16 10:42 PM
01/22/16 10:42 PM
crabman173
crabman173
I have the Steens in stock----USA made--super quality--good as Comps if not way better $375 set yea you can't Google them--they keep low profile and just keep on making some of the best private label parts ever--
Good to 650 open easy as pie want 750 and up on open--( you lifter killer you) go with some bushed Morels and pay out the y8ing yang OR...run reasonable lower pressures than are asked for by the crazy computer designed lobe crowd--run a reasonable lobe and get by with less $$$ lifters or...pay $900 for lifters run 1000 lbs open and still loose that bracket race round by .003
These days the newest lobes "require" stupid spring pressures you are probably not in a COMP Eliminator class turning 11K RPM so ...
Keep it reasonable--keep it in one piece--keep $$ under control
Stay away from Johnsons ( labeled as many names you know)
Steens are way cool lifters for the dough
Re: Solid roller lifters for big block... [Re: ] #1996663
01/22/16 11:00 PM
01/22/16 11:00 PM
Washington
madscientist Offline
Washington
What diameter is the lifter wheen on the Steens??
Re: Solid roller lifters for big block... [Re: ] #1996665
01/22/16 11:05 PM
01/22/16 11:05 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
do they make offset lifters?
Re: Solid roller lifters for big block... [Re: dartman366] #1996706
01/22/16 11:54 PM
01/22/16 11:54 PM
crabman173
crabman173
no offsets I think wheel is .750 have to check but feel sure that is what they are
Re: Solid roller lifters for big block... [Re: rebel] #1996718
01/23/16 12:12 AM
01/23/16 12:12 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
MRL sells BAM Products lifters, which are manufactured by a former Crane engineer. It bothers me to hear about that failure, since I bought a set from MRL because they fit my lifter bores better (less clearance) than the COMP / IMM offset lifters I also have. This is the first failure of a BAM lifter I've heard about... down
Re: Solid roller lifters for big block... [Re: dartman366] #1996810
01/23/16 02:25 AM
01/23/16 02:25 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
$900. . I got some Jesel tool steel tie bar lifters, check the price out on those !!!!
Re: Solid roller lifters for big block... [Re: dartman366] #1996866
01/23/16 10:00 AM
01/23/16 10:00 AM
Jerry Kathe Offline
Jerry Kathe  Offline
I'm not a salesman…nor do I attempt to persuade, but here’s some food for thought;
*The best lifters in existence for the most extreme applications do not use bushings.
*Bushings require far more oil supply and flow to prevent skidding.
*Rollers can survive and provide less friction with minimal oil supply.
*Rollers run cooler.
*Load moment on rollers are no different than bushings.
*It’s not the needle v/s bushing concept that prevents or promotes failure.
And finally……
*OEM manufactures do not use bushings. Manufacturing cost in a high production environment would be significantly less with bushings – add that up over millions of OEM lifters produced…..why wouldn’t they use them if they were better and cheaper to produce?
Re: Solid roller lifters for big block... [Re: Jerry Kathe] #1996894
01/23/16 11:50 AM
01/23/16 11:50 AM
crabman173
crabman173
FWIW
Bushed lifters NEED OIL all recent improvements to bushed units is in "oil to bushing" dept Every sort of groove/hole/ditch/passage is being employed BEST ADVICE IS--keep using a normal sane lobe not some stupid -may make another 5 HP computer designed crap lobe that requires giant spring pressure
and...to help prevent "skidding" we have always bead blasted roller lobes adding a "tooth" to them --after tear down it always looks better on the ramps after this easy cheap band-aid
before we did this ramps would show "skidding" This is in circle track applications---it can't hurt IMO
Re: Solid roller lifters for big block... [Re: Jerry Kathe] #1996913
01/23/16 12:25 PM
01/23/16 12:25 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
And finally……
iagree
If the manufacturer has a design to cost initiative .....which I am sure they have had, then we can see the benefit. A cheaper alternative. An they haven't switched over. my twocents laugh2
Re: Solid roller lifters for big block... [Re: dartman366] #1996914
01/23/16 12:27 PM
01/23/16 12:27 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Well, I've been running bushed Crower bushed lifters for 3 years. My spring pressures are 450 on the seat, 1200 open. My 55mm roller cam is close to an inch. So far I have had no failures and that's what it takes to make a predator engine run. I haven't run 650 open pressures in 20 years but if I did, the needle bearing Morel or Comps would be fine. I had problems with those when I got into the 750-800 lbs range, but I have friends that run the Manley 221424 springs and standard offset Comps and they get 200 passes without a problem. I really like the bushed lifters as if they do start to wear out, they don't deposit extremely hard little needle bearings somewhere in your engine. JMO
Re: Solid roller lifters for big block... [Re: dartman366] #1996919
01/23/16 12:30 PM
01/23/16 12:30 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
iv been using morels for about 10yrs now under 600#open pressure. no failures yet. had them rebuilt 3yrs ago. i think i paid $250 for them at the time. sounds like the sheens or morel are the way to go. the morels work great in an unbushed block. the lifter oil galleys leaked real bad on my 360 block with comp and crane lifters. im now going to use them under 650# on my current combo. we will see how it go's.
Re: Solid roller lifters for big block... [Re: camastomcat] #1996929
01/23/16 12:48 PM
01/23/16 12:48 PM
crabman173
crabman173
I agree!!
Just figure most guys here are bracket racers and should stay in the "safe" lane lobe wise but cam makers tend act like we all have an engine like yours and get regular guys off in the weeds with crazy high pressures On the dyno you can really see the diff in lobes and what it takes to control the newest lobes--it is relaxing to run an "old" style lobe that can be controlled with lower pressures--they can still make big beautiful HP in most stock block combos
The proof of all this conversation is the trend of everyone having lifter issues and crushing out the needles--the conversation always starts out--"well..my cam grinder said I need 1000 open" then " I got 20 runs and wheel fell off of lifters" always comes back to the "new" cam they started using
I miss the days of the old .590 solid in a 440 and a J converter--:)
Re: Solid roller lifters for big block... [Re: dartman366] #1996937
01/23/16 12:58 PM
01/23/16 12:58 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Amen
[image][/image]
Page 1 of 3 1 2 3
