Re: Trick Flow intakes open for orders [Re: StealthWedge67] #1995361
01/21/16 03:26 AM
01/21/16 03:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By StealthWedge67
Originally Posted By D-50
I thought air cleaners restrict air flow. I have never had a air cleaner on anything I have raced.
I went back to back runs a few years ago with & without air cleaner. Absolutely NO difference. And that's a drop base with a 3" element.
Like I said in the air cleaner post... did you
re-jet to see if it really does change(performance)..
I know for FACT that any air cleaner is a restriction
so a jet change is required.. its just a matter of how
much of a change and what filter you were running... I
flowed so many air filters it gets BORING.. with and
without adding fine dust to it
wave
Re: Trick Flow intakes open for orders [Re: SpareParts] #1995405
01/21/16 10:05 AM
01/21/16 10:05 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By SpareParts
Originally Posted By 72Swinger
Enlarge the scoop dude!
Stop being snarky and smart-a$$ with your suggestions hahaha the skin is thin here! We're Lucky to have so many options available to us, ford guys have like one choice.
I actually did talk with a local fiberglass specialist about modifying the T/A scoop the same way Dick Landy did, but held off on having it done... $$$
Re: Trick Flow intakes open for orders [Re: D-50] #1995406
01/21/16 10:11 AM
01/21/16 10:11 AM
BradH Offline
BradH  Offline
I guess that is the reason Pro Stock runs air cleaners. Maybe they are worried about the weight.
If I could tear my engine down after every race, I wouldn't be as concerned about what got sucked into it, either.
Re: Trick Flow intakes open for orders [Re: AndyF] #1995487
01/21/16 01:24 PM
01/21/16 01:24 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The comments are not meant to be "snarky" as you are calling it. A low plenum intake is not good for making power and as stated, there are already plenty of those out there. Why would TF invest resources in an inferior product. It's your choice to run a relatively low clearance scoop. You have to decide whether you want the best performance, or you want it to look stock. The two usually don't go hand in hand
Re: Trick Flow intakes open for orders [Re: AndyF] #1995546
01/21/16 03:38 PM
01/21/16 03:38 PM
an8sec70cuda Offline
Patrick at Pro Systems told me that if the car does not go faster w/ NO air cleaner/filter, then the mix is wrong.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Trick Flow intakes open for orders [Re: AndyF] #1995839
01/21/16 09:28 PM
01/21/16 09:28 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Put a throttle body on it with EFI, that should gain you an inch at least.
https://www.accufabracing.com/components...5-1-600x300.jpg
Mopar to the bone!!!
Re: Trick Flow intakes open for orders [Re: AndyF] #1995991
01/21/16 11:51 PM
01/21/16 11:51 PM
AndyF Offline OP
AndyF  Offline OP
I got an email from Trick Flow saying the intakes are very close to being ready to ship. They didn't give me a date but sounds like near future.
Re: Trick Flow intakes open for orders [Re: StealthWedge67] #1996014
01/22/16 12:14 AM
01/22/16 12:14 AM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
Sure looks like an Eddy Victor.
that's what I was thinking also..
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
Re: Trick Flow intakes open for orders [Re: AndyF] #1996083
01/22/16 02:19 AM
01/22/16 02:19 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
For those worried about hood clearance there's a part you can try that might provide that extra little bit of room. If you have a 4150 carb and a 14" air cleaner, go to the Chevrolet dealer and order part #6422188 - it's a drop base originally designed for mid '60s Chevrolet muscle cars with the 780 Holley. It drops about an inch lower than any aftermarket drop base you can find.
Re: Trick Flow intakes open for orders [Re: AndyF] #1996274
01/22/16 01:54 PM
01/22/16 01:54 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Another Chevy part!? good grief...<end sarcasm>
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Trick Flow intakes open for orders [Re: OUTLAWD] #1996403
01/22/16 04:59 PM
01/22/16 04:59 PM
dogdays Offline
dogdays  Offline
I have two. One original Z-28 and one from 15 years later. They are low for sure, and make a really nice entrance to the carburetor.
But, the air filter assembly was very expensive, so bring plenty of coin. Don't know what just the base would cost.
Wow, I just looked them up. The entire assembly for $85 or the base for $60. I remember the dealer list as $145.00, and that was 20+ years ago.
R.
Re: Trick Flow intakes open for orders [Re: AndyF] #1996408
01/22/16 05:10 PM
01/22/16 05:10 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Thats actually not too bad compared to your regular cheap universal air cleaners everyone is selling!
Re: Trick Flow intakes open for orders [Re: dogdays] #1996655
01/22/16 10:48 PM
01/22/16 10:48 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
R.
I just buy the base, and pair it with an aftermarket 14" top and filter. Years ago I had a 3" K&N element and Moroso lid under the stock flat hood of a '67 cuda 440 with Holley Street Dominator and 850 dp.
The one I showed is a spare one I bought about 15 years ago, was like $30 back then.
My old 440 cuda street beater in about '92-93. Flat hood, mufflers, 9" tires, 11s on 92 octane
(I know it was rough - didn't care back then)
Re: Trick Flow intakes open for orders [Re: 451Cuda] #1996695
01/22/16 11:41 PM
01/22/16 11:41 PM
Nebraska
TT5 Valiant Offline
TT5 Valiant  Offline
Nebraska
R.
I miss that car and those years of O street!
Re: Trick Flow intakes open for orders [Re: TT5 Valiant] #1996713
01/23/16 12:03 AM
01/23/16 12:03 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
O street is gonna be interesting again very soon.
