Re: Which used Gen 3 should I buy?
[Re: galen]
#1995758
01/21/16 07:37 PM
01/21/16 07:37 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Those would be good blocks,acc. drives for a turbo build. I would'nt pay extra for those heads,coils, intakes or ecm's though. If you can score the short blocks with the acc. and timing covers then hell yes.
Mopar to the bone!!!
[Re: 72Swinger]
#1996731
01/23/16 12:22 AM
01/23/16 12:22 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Those would be good blocks,acc. drives for a turbo build. I wouldn't pay extra for those heads,coils, intakes or ecm's though. If you can score the short blocks with the acc. and timing covers then hell yes. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) 5.7 shortblock would be ideal. Score a set of Eagle heads. Truck timing cover will mount alternator up high. Charger/300 cover will put alternator and a/c down low. If you don't use headers, get a set of 6.1 manifolds. Next best thing to shorty headers, breathe much better than 5.7 logs. LXforums has got lots of used parts.
[image][/image]
[Re: sgcuda]
#1998633
01/25/16 09:05 PM
01/25/16 09:05 PM
Posts: 836 Missouri
galen
Missouri
Those would be good blocks,acc. drives for a turbo build. I wouldn't pay extra for those heads,coils, intakes or ecm's though. If you can score the short blocks with the acc. and timing covers then hell yes. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) 5.7 shortblock would be ideal. Score a set of Eagle heads. Truck timing cover will mount alternator up high. Charger/300 cover will put alternator and a/c down low. If you don't use headers, get a set of 6.1 manifolds. Next best thing to shorty headers, breathe much better than 5.7 logs. LXforums has got lots of used parts. Thanks guys. You got me thinking. I was going to buy complete but I now realize I would end up not using most of it. Plus I did not consider it having the wrong timing cover. I will look for a shortblock or bare block.
