Re: Which used Gen 3 should I buy?
[Re: galen]
#1995758
01/21/16 07:37 PM
01/21/16 07:37 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Those would be good blocks,acc. drives for a turbo build. I would'nt pay extra for those heads,coils, intakes or ecm's though. If you can score the short blocks with the acc. and timing covers then hell yes.
Mopar to the bone!!!
[Re: 72Swinger]
#1996731
01/23/16 12:22 AM
01/23/16 12:22 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Those would be good blocks,acc. drives for a turbo build. I wouldn't pay extra for those heads,coils, intakes or ecm's though. If you can score the short blocks with the acc. and timing covers then hell yes. 5.7 shortblock would be ideal. Score a set of Eagle heads. Truck timing cover will mount alternator up high. Charger/300 cover will put alternator and a/c down low. If you don't use headers, get a set of 6.1 manifolds. Next best thing to shorty headers, breathe much better than 5.7 logs. LXforums has got lots of used parts.
[image][/image]
[Re: sgcuda]
#1998633
01/25/16 09:05 PM
01/25/16 09:05 PM
Posts: 834 Missouri
galen
Missouri
Those would be good blocks,acc. drives for a turbo build. I wouldn't pay extra for those heads,coils, intakes or ecm's though. If you can score the short blocks with the acc. and timing covers then hell yes. 5.7 shortblock would be ideal. Score a set of Eagle heads. Truck timing cover will mount alternator up high. Charger/300 cover will put alternator and a/c down low. If you don't use headers, get a set of 6.1 manifolds. Next best thing to shorty headers, breathe much better than 5.7 logs. LXforums has got lots of used parts. Thanks guys. You got me thinking. I was going to buy complete but I now realize I would end up not using most of it. Plus I did not consider it having the wrong timing cover. I will look for a shortblock or bare block.
