Re: Kaiser M715 Axletech 4000
[Re: EV2DEMON]
#1995551
01/21/16 03:43 PM
01/21/16 03:43 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
I assume you can get hydraulic calipers for the Axles? What do those things weigh? Black Rock Fab makes brackets for both Dodge 2500 calipers and Ford F750 calipers. I have a set of the Dodge ones on order. Axles are 1500lbs and 1300lbs with the air calipers. They weigh 1100 and 900 with the Dodge calipers
[Re: Defbob]
#1995633
01/21/16 05:26 PM
01/21/16 05:26 PM
Posts: 760 Canada
CTD5.9
Canada
I assume you can get hydraulic calipers for the Axles? What do those things weigh? Black Rock Fab makes brackets for both Dodge 2500 calipers and Ford F750 calipers. I have a set of the Dodge ones on order. Axles are 1500lbs and 1300lbs with the air calipers. They weigh 1100 and 900 with the Dodge calipers Any room for more lightening on them or is that about it?
[Re: CTD5.9]
#1996526
01/22/16 08:00 PM
01/22/16 08:00 PM
Defbob
Norwich CT USA
I assume you can get hydraulic calipers for the Axles? What do those things weigh? Black Rock Fab makes brackets for both Dodge 2500 calipers and Ford F750 calipers. I have a set of the Dodge ones on order. Axles are 1500lbs and 1300lbs with the air calipers. They weigh 1100 and 900 with the Dodge calipers Any room for more lightening on them or is that about it? No, but a trussed D60 weighs almost as much and isn't as strong
[Re: GY3]
#1996527
01/22/16 08:00 PM
01/22/16 08:00 PM
Defbob
Norwich CT USA
Very cool build!
Are you going diesel or LS with this one? No diesels for me anymore. Either SBC, BBC, or LS
[Re: Defbob]
#1998080
01/25/16 12:37 AM
01/25/16 12:37 AM
Posts: 760 Canada
CTD5.9
Canada
These all have air lockers correct? I suppose I would be running a pinion brake since its not on the road, would save one disc/calipers worth of weight.
