Kaiser M715 Axletech 4000 #1994326
01/19/16 08:27 PM
01/19/16 08:27 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
After selling my 6BT powered M715 last year, I missed having it. I found a super clean and complete 1968 Kaiser M715. I will drive it the way it is for a couple years, then the Axletech 4000s are going in.
Re: Kaiser M715 Axletech 4000 [Re: Defbob] #1994985
01/20/16 04:40 PM
01/20/16 04:40 PM
Friendly, WV
wedgeheaded Offline
wedgeheaded  Offline
Friendly, WV
That's pretty cool. I like where you're head is.
Re: Kaiser M715 Axletech 4000 [Re: Defbob] #1995192
01/20/16 10:55 PM
01/20/16 10:55 PM
Indiana
EV2DEMON Offline
The Camaro Kid
EV2DEMON  Offline
The Camaro Kid
Indiana
I assume you can get hydraulic calipers for the Axles? What do those things weigh?
Re: Kaiser M715 Axletech 4000 [Re: EV2DEMON] #1995551
01/21/16 03:43 PM
01/21/16 03:43 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Black Rock Fab makes brackets for both Dodge 2500 calipers and Ford F750 calipers. I have a set of the Dodge ones on order. Axles are 1500lbs and 1300lbs with the air calipers. They weigh 1100 and 900 with the Dodge calipers
Re: Kaiser M715 Axletech 4000 [Re: Defbob] #1995633
01/21/16 05:26 PM
01/21/16 05:26 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Any room for more lightening on them or is that about it?
Re: Kaiser M715 Axletech 4000 [Re: CTD5.9] #1996495
01/22/16 07:06 PM
01/22/16 07:06 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Very cool build!
Are you going diesel or LS with this one?
Re: Kaiser M715 Axletech 4000 [Re: CTD5.9] #1996526
01/22/16 08:00 PM
01/22/16 08:00 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
No, but a trussed D60 weighs almost as much and isn't as strong
Re: Kaiser M715 Axletech 4000 [Re: GY3] #1996527
01/22/16 08:00 PM
01/22/16 08:00 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Originally Posted By GY3
Very cool build!
No diesels for me anymore. Either SBC, BBC, or LS
Re: Kaiser M715 Axletech 4000 [Re: Defbob] #1996528
01/22/16 08:01 PM
01/22/16 08:01 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
This truck has the same axles and t-case...
https://youtu.be/cDoRmT0iRic
Re: Kaiser M715 Axletech 4000 [Re: Defbob] #1997513
01/24/16 03:28 AM
01/24/16 03:28 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Not asking to step on your |\|UT$ but why no Mopar power?
Re: Kaiser M715 Axletech 4000 [Re: Defbob] #1997857
01/24/16 07:35 PM
01/24/16 07:35 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I want to retain the T98 tranny since it has the PTO for the mechanical winch. Or else it would be getting a 440 stroker...
Re: Kaiser M715 Axletech 4000 [Re: Defbob] #1998080
01/25/16 12:37 AM
01/25/16 12:37 AM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
These all have air lockers correct? I suppose I would be running a pinion brake since its not on the road, would save one disc/calipers worth of weight.
Re: Kaiser M715 Axletech 4000 [Re: Defbob] #2001027
01/29/16 10:02 AM
01/29/16 10:02 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Yes, they have air lockers. Air to release. I would keep the brakes at the wheels. The pinion is low and centered unlike a toploader rockwell.
Re: Kaiser M715 Axletech 4000 [Re: Defbob] #2002188
01/30/16 08:42 PM
01/30/16 08:42 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I picked up some aluminum MRAP rims
Re: Kaiser M715 Axletech 4000 [Re: Defbob] #2002206
01/30/16 09:00 PM
01/30/16 09:00 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I also got a set of caliper brackets from Black Rock Fab. These allow me to use front hydraulic calipers off of a Dodge Ram 2500
Re: Kaiser M715 Axletech 4000 [Re: Defbob] #2002662
01/31/16 02:37 PM
01/31/16 02:37 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Where's the Beef? Oh I know!!! Defbob took it all and put it on his Kaiser M715 axle swap! Those are some crazy heavy parts. Will this be street legal or off road only?
Re: Kaiser M715 Axletech 4000 [Re: WO23Coronet] #2003794
02/01/16 10:43 PM
02/01/16 10:43 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
It'll be street legal-ish. The axles are the narrow version. They don't stick out very much on a K5 Jimmy, so my flares should cover them up good.
