Why can't you use solid lifters with a hydraulic cam? #1995206
01/20/16 11:20 PM
01/20/16 11:20 PM
Phoenix, AZ
Jjs72D Offline OP
Deep in the closet
Jjs72D  Offline OP
Deep in the closet
Phoenix, AZ
I have read in some dyno tests where solid lifters have been used on hydraulic cams but at the same time, I have never understood what makes each style unique? Aside from the inner function, is the taper much different?
Re: Why can't you use solid lifters with a hydraulic cam? [Re: Jjs72D] #1995215
01/20/16 11:32 PM
01/20/16 11:32 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The only reasons I can think of are solid cams generally have higher lifts and shorter durations making the ramps a too harsh for a hydraulic to handle ... as well there's the increased valvespring pressure which will fight the hydraulic system.
Re: Why can't you use solid lifters with a hydraulic cam? [Re: Stanton] #1995222
01/20/16 11:45 PM
01/20/16 11:45 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
This topic may take a lot of popcorn
11B40
Re: Why can't you use solid lifters with a hydraulic cam? [Re: Jjs72D] #1995253
01/21/16 12:32 AM
01/21/16 12:32 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
This topic comes up on Speedtalk, it's because hydraulic cams don't have "lash ramps". What those exactly are I don't know, but I'm guessing the initial ramp of the lobe may be milder than a hydraulic to take up the lash smoothly so it doesn't slam closed the clearance, but that's a total guess.
Re: Why can't you use solid lifters with a hydraulic cam? [Re: Jjs72D] #1995284
01/21/16 01:15 AM
01/21/16 01:15 AM
I know a very successful SCCA engine builder that uses solid lifters on hydraulic lifter camshafts in some of his spec. class motors, he set the lash at .0010 to no more than .0030 hot work shruggy
Re: Why can't you use solid lifters with a hydraulic cam? [Re: Jjs72D] #1995364
01/21/16 04:02 AM
01/21/16 04:02 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I would ask why? the wiping out of the cam is probably more so than breaking in a solid lifter cam. so why take the chance, similar grinds are available and most hydraulic/lifter cams today can hang right with a solid.
Re: Why can't you use solid lifters with a hydraulic cam? [Re: Jjs72D] #1995368
01/21/16 05:08 AM
01/21/16 05:08 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I understand one can do it but because the hyd cam profile is designed for zero lash and solids need some amount of lash the duration is changed. iirc, peak torque and hp move down in the rpm range. Conversely, if a hyd cam is used on a solid lifter cam the peak tq/hp moves up the chart
rowing4 is on the mark, there are so many grinds available to put the curve wherever one desires. also if high hp/rpm is in order I think solid is still the best bet.
Re: Why can't you use solid lifters with a hydraulic cam? [Re: srt] #1995399
01/21/16 09:40 AM
01/21/16 09:40 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
This doesn't sound like an experiment that's worth trying.
Re: Why can't you use solid lifters with a hydraulic cam? [Re: Cab_Burge] #1995432
01/21/16 11:12 AM
01/21/16 11:12 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I have heard it done before by others, never talked to someone personally who done it. With a hydraulic cam, I don't think the solid lifters don't really gain you anything. Solids tend to have more aggressive lobes to take advantage of the solid lifter design.
Re: Why can't you use solid lifters with a hydraulic cam? [Re: Jjs72D] #1995449
01/21/16 12:06 PM
01/21/16 12:06 PM
Idaho
LaRoy Engines Offline
Idaho
You can. I have done it successfully over the years. Keep a tight valve lash, no more that .006" hot lash. Makes things tough on a aluminum head project. But for me it has extended the rpm range of the camshaft. Have the dyno tests in a folder around here somewhere.
Re: Why can't you use solid lifters with a hydraulic cam? [Re: Jjs72D] #1995477
01/21/16 01:16 PM
01/21/16 01:16 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I'm sure the Stock Eliminator guys have it figured out
Abe Lincoln
Re: Why can't you use solid lifters with a hydraulic cam? [Re: dart4forte] #1995516
01/21/16 02:42 PM
01/21/16 02:42 PM
iagree whistlingMany years ago whistling
Re: Why can't you use solid lifters with a hydraulic cam? [Re: TooMany62s] #1995521
01/21/16 02:50 PM
01/21/16 02:50 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
In 1973 I did just that. I had a rebuilt 383 and put adjustable rockers with solid lifters on the stock hyd. cam. It ran fine and stayed that way(months) until I screwed up and didn't drain all the water out of the block for the winter.
Re: Why can't you use solid lifters with a hydraulic cam? [Re: 52savoy] #1995727
01/21/16 07:11 PM
01/21/16 07:11 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
the hyd cam lobe has sideways slant to it so it rotates the lifter so they don't wear out, you can use solid but they do not seat flat on lobe
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Why can't you use solid lifters with a hydraulic cam? [Re: Stanton] #1995751
01/21/16 07:33 PM
01/21/16 07:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
He is asking about a solid lifter on a hyd cam so the ramp issue you talk about is a non issue, I agree with your spring theroy but that only requires the springs be changed ,
Comp sells/used to sell a set of hyd lifters that come with an instruction sheet telling the user to run .002 lash, I have a set.
Re: Why can't you use solid lifters with a hydraulic cam? [Re: 440lebaron] #1995753
01/21/16 07:33 PM
01/21/16 07:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Solids have to rotate also .
Re: Why can't you use solid lifters with a hydraulic cam? [Re: 440lebaron] #1995810
01/21/16 08:32 PM
01/21/16 08:32 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Solid and hydraulic cams both have an angle ground into the cam face along with a slight dome on the lifter face to keep the lifter rotating. If the lifter stops rotating it is instant disaster.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Why can't you use solid lifters with a hydraulic cam? [Re: MoparforLife] #1995871
01/21/16 09:58 PM
01/21/16 09:58 PM
dogdays Offline
dogdays  Offline
And the angle is the same for both except the original Six Pack cam which had a smaller taper.
R.
Re: Why can't you use solid lifters with a hydraulic cam? [Re: Jjs72D] #1995882
01/21/16 10:14 PM
01/21/16 10:14 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
There's always Schubec lifters
Abe Lincoln
Re: Why can't you use solid lifters with a hydraulic cam? [Re: Jjs72D] #1996118
01/22/16 04:09 AM
01/22/16 04:09 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Lol..alot of bad info on this thread....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
