Re: Why can't you use solid lifters with a hydraulic cam?
[Re: Jjs72D]
#1995364
01/21/16 04:02 AM
01/21/16 04:02 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I would ask why? the wiping out of the cam is probably more so than breaking in a solid lifter cam. so why take the chance, similar grinds are available and most hydraulic/lifter cams today can hang right with a solid.
[Re: Jjs72D]
#1995449
01/21/16 12:06 PM
01/21/16 12:06 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
You can. I have done it successfully over the years. Keep a tight valve lash, no more that .006" hot lash. Makes things tough on a aluminum head project. But for me it has extended the rpm range of the camshaft. Have the dyno tests in a folder around here somewhere.
[Re: Jjs72D]
#1995477
01/21/16 01:16 PM
01/21/16 01:16 PM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
I'm sure the Stock Eliminator guys have it figured out
Abe Lincoln
[Re: TooMany62s]
#1995521
01/21/16 02:50 PM
01/21/16 02:50 PM
Posts: 4,258 State of Fascism
52savoy
State of Fascism
This doesn't sound like an experiment that's worth trying. In 1973 I did just that. I had a rebuilt 383 and put adjustable rockers with solid lifters on the stock hyd. cam. It ran fine and stayed that way(months) until I screwed up and didn't drain all the water out of the block for the winter.
[Re: 52savoy]
#1995727
01/21/16 07:11 PM
01/21/16 07:11 PM
Posts: 1,613 westerly, ri. usa
440lebaron
westerly, ri. usa
the hyd cam lobe has sideways slant to it so it rotates the lifter so they don't wear out, you can use solid but they do not seat flat on lobe
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: Stanton]
#1995751
01/21/16 07:33 PM
01/21/16 07:33 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
The only reasons I can think of are solid cams generally have higher lifts and shorter durations making the ramps a too harsh for a hydraulic to handle ... as well there's the increased valvespring pressure which will fight the hydraulic system. He is asking about a solid lifter on a hyd cam so the ramp issue you talk about is a non issue, I agree with your spring theroy but that only requires the springs be changed , Comp sells/used to sell a set of hyd lifters that come with an instruction sheet telling the user to run .002 lash, I have a set.
[Re: 440lebaron]
#1995753
01/21/16 07:33 PM
01/21/16 07:33 PM
JohnRR
the hyd cam lobe has sideways slant to it so it rotates the lifter so they don't wear out, you can use solid but they do not seat flat on lobe Solids have to rotate also .
[Re: 440lebaron]
#1995810
01/21/16 08:32 PM
01/21/16 08:32 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
the hyd cam lobe has sideways slant to it so it rotates the lifter so they don't wear out, you can use solid but they do not seat flat on lobe Solid and hydraulic cams both have an angle ground into the cam face along with a slight dome on the lifter face to keep the lifter rotating. If the lifter stops rotating it is instant disaster.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: Jjs72D]
#1995882
01/21/16 10:14 PM
01/21/16 10:14 PM
dart4forte
Mesa, Arizona
There's always Schubec lifters
Abe Lincoln
[Re: Jjs72D]
#1996118
01/22/16 04:09 AM
01/22/16 04:09 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Lol..alot of bad info on this thread....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
