Master cylinder for 4 wheel manual disc? #1994989
01/20/16 04:46 PM
01/20/16 04:46 PM
bigfork mn
dragram440 Offline OP
bigfork mn
What is a good master cylinder to run with 4 wheel manual disc brakes. I am putting together a rear disc setup for the Dana 60 Im putting together right now. I am using GM metric calipers and using 1980's Diplomat front disc brakes. I also ordered a adjustable propotioning valve. I was running stock rear drums and the Diplomat disc up front with a 94 Dodge Ram aluminum master cylinder but the issue I have now is the peddle is very hard. The brakes work ok but it takes both feet to stop it from 125 mph. The Ram master has a really big piston and is actually a power brake master. I was thinking I needed a manual brake master with a smaller piston. I would like to stay with the aluminum master if possible.
67' charger 499 RB 10.57 at 127
Re: Master cylinder for 4 wheel manual disc? [Re: dragram440] #1995041
01/20/16 05:33 PM
01/20/16 05:33 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have one of DRdiffs 15/16" on my Dart and it's a ton better than the 1 1/32" that it replaced. If I ever have to replace it I'll use a 7/8" bore. I have gutted factory 73 valve that I use as a distribution block and an adjustable proportioning in the rear line, but it's open all the way.
Re: Master cylinder for 4 wheel manual disc? [Re: dragram440] #1995046
01/20/16 05:40 PM
01/20/16 05:40 PM
bigfork mn
bigfork mn
I should have ordered one from him this morning when I ordered all my Dana 60 parts!
Re: Master cylinder for 4 wheel manual disc? [Re: dragram440] #1995049
01/20/16 05:42 PM
01/20/16 05:42 PM
Chicago adjacent
WS68SSC Offline
Newest
WS68SSC  Offline
Newest
Chicago adjacent
justinp61 is right, Dr. Diff is the man. Good affordable stuff!
And personally I would use calipers off of a Jeep Cherokee. I am not a fan of cross breeding garbage Chebby parts on a Mopar.
Re: Master cylinder for 4 wheel manual disc? [Re: WS68SSC] #1995075
01/20/16 06:22 PM
01/20/16 06:22 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Do you have a part number handy to use Jeep calipers??? Most aftermarket kits use a GM metric caliper or a Ford calipers so if you have an alternative please enlighten us.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Master cylinder for 4 wheel manual disc? [Re: dragram440] #1995099
01/20/16 07:13 PM
01/20/16 07:13 PM
Chicago adjacent
WS68SSC Offline
Newest
WS68SSC  Offline
Newest
Chicago adjacent
Yeah it's called get off your a** and test it out. Anyone can just pick a set out of a catalog. What happened to the pride? I have seen several set ups with mopar brand disc brake set ups. Yet everyone jumps on the chevy band wagon.
Re: Master cylinder for 4 wheel manual disc? [Re: WS68SSC] #1995155
01/20/16 09:24 PM
01/20/16 09:24 PM
Rittman Ohio
Rittman Ohio
Billy if you have seen "several" setups then why can't you name one??? The guy you refer to as "THE MAN" offers his upgrade kits with GM and Ford calipers but he must not want to get off his "a**" either. The GM metric caliper has about a dozen different compounds depending on what type of racing you plan on doing so why would I want to put an inferior designed caliper on my race car? You "MOPAR OR NOCAR" types always make me laugh to myself putting second rate parts on your car out of some blind loyalty in a company that couldn't care less about you.
But this is America and we can all build our cars the way we want to shruggy
Good luck and I hope Fiat/Chrysler sends you a thank you letter for your blind faith in their engineering department eyes
Gus beer
64 Plymouth Savoy
Dana 60
Re: Master cylinder for 4 wheel manual disc? [Re: dragram440] #1995156
01/20/16 09:31 PM
01/20/16 09:31 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I just finished E-mailing Cass about a m/c for the 72 Duster.
I am going manual brakes with Wilwood discs on all 4 corners. He suggested using the 15/16" bore M/C. twocents
...FAFO...
Re: Master cylinder for 4 wheel manual disc? [Re: dragram440] #1995173
01/20/16 10:09 PM
01/20/16 10:09 PM
Chicago adjacent
WS68SSC Offline
Newest
WS68SSC  Offline
Newest
Chicago adjacent
I have a friend who used rear the caliper set up off of a Jeep Cherokee. I'll get ahold of him and have take pics.
Re: Master cylinder for 4 wheel manual disc? [Re: dragram440] #1995252
01/21/16 12:30 AM
01/21/16 12:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Measure the master cyl bore you have on it now..
its just to large... you have a very hard pedal
and it moves very little distance.. correct...
put a smaller bore master on it
EDIT
here is some reading for you on ratios and masters
http://www.markwilliams.com/braketech.aspx
wave
Re: Master cylinder for 4 wheel manual disc? [Re: MR_P_BODY] #1995404
01/21/16 10:03 AM
01/21/16 10:03 AM
moparx Offline
moparx  Offline
member FEETS has a good brake tech thread over on the "corners are best" section of the board to check out also.
beer
Re: Master cylinder for 4 wheel manual disc? [Re: dragram440] #1995496
01/21/16 01:47 PM
01/21/16 01:47 PM
gregsdart Offline
gregsdart  Offline
I run a 7/8 bore Mopar cast iron unit on my street Dart, works well with Wilwood front discs, Ford Explorer discs on the back (oops, sorry I mentioned cross breeding) . The travel is a touch more than I like, but is stops very well with little effort.
Re: Master cylinder for 4 wheel manual disc? [Re: WS68SSC] #1995536
01/21/16 03:17 PM
01/21/16 03:17 PM
midwest
superchuck Offline
On thin ice
superchuck  Offline
On thin ice
midwest
Chevy bandwagon stops my car just fine! My pride is when I see the win light.
Re: Master cylinder for 4 wheel manual disc? [Re: fourgearsavoy] #1995608
01/21/16 04:50 PM
01/21/16 04:50 PM
Chicago adjacent
WS68SSC Offline
Newest
WS68SSC  Offline
Newest
Chicago adjacent
Gus beer
But we are not talking modern age cars. We are talking about cars that were built in an era of pride and affordability. I know growing up and racing where I live, a Chevy guy would pass you up on the side of the road if you were broke down just because you had a Mopar. Just full of alot mpre vintage pride and history. Just my two cents
Re: Master cylinder for 4 wheel manual disc? [Re: dragram440] #1995613
01/21/16 04:57 PM
01/21/16 04:57 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Master cylinder for 4 wheel manual disc? [Re: gregsdart] #1995635
01/21/16 05:30 PM
01/21/16 05:30 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
That's what my Dart had on it, the car felt like it would just sit down when I got on the brakes. I wish I'd looked for a kit and just rebuilt it.
Re: Master cylinder for 4 wheel manual disc? [Re: WS68SSC] #1995729
01/21/16 07:12 PM
01/21/16 07:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
But we are not talking modern age cars. We are talking about cars that were built in an era of pride and affordability. I know growing up and racing where I live, a Chevy guy would pass you up on the side of the road if you were broke down just because you had a Mopar. Just full of alot mpre vintage pride and history. Just my two cents [/quote]
We are talking hydraulics here.. nothing more..
if you can find/buy a cheaper caliper and make it
work whats wrong with that... all this is, is bore
and ratio stuff for a certain size caliper bore...
its simple hydraulics
wave
