Master cylinder for 4 wheel manual disc?
#1994989
01/20/16 04:46 PM
01/20/16 04:46 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
What is a good master cylinder to run with 4 wheel manual disc brakes. I am putting together a rear disc setup for the Dana 60 Im putting together right now. I am using GM metric calipers and using 1980's Diplomat front disc brakes. I also ordered a adjustable propotioning valve. I was running stock rear drums and the Diplomat disc up front with a 94 Dodge Ram aluminum master cylinder but the issue I have now is the peddle is very hard. The brakes work ok but it takes both feet to stop it from 125 mph. The Ram master has a really big piston and is actually a power brake master. I was thinking I needed a manual brake master with a smaller piston. I would like to stay with the aluminum master if possible.
67' charger 499 RB
10.57 at 127
Re: Master cylinder for 4 wheel manual disc?
[Re: dragram440]
#1995046
01/20/16 05:40 PM
01/20/16 05:40 PM
dragram440
bigfork mn
I should have ordered one from him this morning when I ordered all my Dana 60 parts!
67' charger 499 RB
10.57 at 127
[Re: WS68SSC]
#1995075
01/20/16 06:22 PM
01/20/16 06:22 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
justinp61 is right, Dr. Diff is the man. Good affordable stuff!
And personally I would use calipers off of a Jeep Cherokee. I am not a fan of cross breeding garbage Chebby parts on a Mopar. Do you have a part number handy to use Jeep calipers??? Most aftermarket kits use a GM metric caliper or a Ford calipers so if you have an alternative please enlighten us. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: WS68SSC]
#1995155
01/20/16 09:24 PM
01/20/16 09:24 PM
fourgearsavoy
Rittman Ohio
Yeah it's called get off your a** and test it out. Anyone can just pick a set out of a catalog. What happened to the pride? I have seen several set ups with mopar brand disc brake set ups. Yet everyone jumps on the chevy band wagon. Billy if you have seen "several" setups then why can't you name one??? The guy you refer to as "THE MAN" offers his upgrade kits with GM and Ford calipers but he must not want to get off his "a**" either. The GM metric caliper has about a dozen different compounds depending on what type of racing you plan on doing so why would I want to put an inferior designed caliper on my race car? You "MOPAR OR NOCAR" types always make me laugh to myself putting second rate parts on your car out of some blind loyalty in a company that couldn't care less about you. But this is America and we can all build our cars the way we want to Good luck and I hope Fiat/Chrysler sends you a thank you letter for your blind faith in their engineering department Gus
[Re: dragram440]
#1995156
01/20/16 09:31 PM
01/20/16 09:31 PM
Posts: 5,107 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I just finished E-mailing Cass about a m/c for the 72 Duster. I am going manual brakes with Wilwood discs on all 4 corners. He suggested using the 15/16" bore M/C.
...FAFO...
[Re: dragram440]
#1995252
01/21/16 12:30 AM
01/21/16 12:30 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Measure the master cyl bore you have on it now.. its just to large... you have a very hard pedal and it moves very little distance.. correct... put a smaller bore master on it EDIT here is some reading for you on ratios and masters http://www.markwilliams.com/braketech.aspx
[Re: dragram440]
#1995496
01/21/16 01:47 PM
01/21/16 01:47 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I run a 7/8 bore Mopar cast iron unit on my street Dart, works well with Wilwood front discs, Ford Explorer discs on the back (oops, sorry I mentioned cross breeding) . The travel is a touch more than I like, but is stops very well with little effort.
[Re: WS68SSC]
#1995536
01/21/16 03:17 PM
01/21/16 03:17 PM
Posts: 200 midwest
superchuck
On thin ice
On thin ice
midwest
What happened to the pride? I have seen several set ups with mopar brand disc brake set ups. Yet everyone jumps on the chevy band wagon. Chevy bandwagon stops my car just fine! My pride is when I see the win light.
[Re: fourgearsavoy]
#1995608
01/21/16 04:50 PM
01/21/16 04:50 PM
Posts: 299 Chicago adjacent
WS68SSC
Newest
Newest
Chicago adjacent
Yeah it's called get off your a** and test it out. Anyone can just pick a set out of a catalog. What happened to the pride? I have seen several set ups with mopar brand disc brake set ups. Yet everyone jumps on the chevy band wagon. Billy if you have seen "several" setups then why can't you name one??? The guy you refer to as "THE MAN" offers his upgrade kits with GM and Ford calipers but he must not want to get off his "a**" either. The GM metric caliper has about a dozen different compounds depending on what type of racing you plan on doing so why would I want to put an inferior designed caliper on my race car? You "MOPAR OR NOCAR" types always make me laugh to myself putting second rate parts on your car out of some blind loyalty in a company that couldn't care less about you. But this is America and we can all build our cars the way we want to Good luck and I hope Fiat/Chrysler sends you a thank you letter for your blind faith in their engineering department Gus But we are not talking modern age cars. We are talking about cars that were built in an era of pride and affordability. I know growing up and racing where I live, a Chevy guy would pass you up on the side of the road if you were broke down just because you had a Mopar. Just full of alot mpre vintage pride and history. Just my two cents
[Re: dragram440]
#1995613
01/21/16 04:57 PM
01/21/16 04:57 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: gregsdart]
#1995635
01/21/16 05:30 PM
01/21/16 05:30 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I run a 7/8 bore Mopar cast iron unit on my street Dart, works well with Wilwood front discs, Ford Explorer discs on the back (oops, sorry I mentioned cross breeding) . The travel is a touch more than I like, but is stops very well with little effort. That's what my Dart had on it, the car felt like it would just sit down when I got on the brakes. I wish I'd looked for a kit and just rebuilt it.
[Re: WS68SSC]
#1995729
01/21/16 07:12 PM
01/21/16 07:12 PM
MR_P_BODY
But we are not talking modern age cars. We are talking about cars that were built in an era of pride and affordability. I know growing up and racing where I live, a Chevy guy would pass you up on the side of the road if you were broke down just because you had a Mopar. Just full of alot mpre vintage pride and history. Just my two cents [/quote] We are talking hydraulics here.. nothing more.. if you can find/buy a cheaper caliper and make it work whats wrong with that... all this is, is bore and ratio stuff for a certain size caliper bore... its simple hydraulics
