440-1 heaads with Jesel rockers ,pushrod rubbng problems
#1994455
01/19/16 11:03 PM
01/19/16 11:03 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
I'm mocking up a 400 block bracket motor with a set of 440-1 heads I bought off of a member on here in the past,I'm having pushrod rubbing problems on two intake port runners(#1 and #7) on the drivers side using 7/16 O.D. pushrods with the Jesel 1.55 ratio paired rocker arms. I did swap those two pushrods to a smaller 3/8 diameter and they didn't rub when on the heel of the cam but they did hit at mid to max lift I haven't mock up the other side up yet so I don't know if they will hit on that side also, my question is, is this common All input apreciated
Re: 440-1 heaads with Jesel rockers ,pushrod rubbng problems
[Re: gregsdart]
#1994808
01/20/16 12:14 PM
01/20/16 12:14 PM
Jerry Kathe
Jesel 1.55 rockers here, same trouble with clearance. I run offset lifters already, still needed more roofom for 7/16 or bigger pushrods. Low deck?
[Re: Jerry Kathe]
#1994827
01/20/16 12:46 PM
01/20/16 12:46 PM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Jesel 1.55 rockers here, same trouble with clearance. I run offset lifters already, still needed more roofom for 7/16 or bigger pushrods. Low deck? Megablock
[Re: Jerry Kathe]
#1994937
01/20/16 03:30 PM
01/20/16 03:30 PM
Cab_Burge
Mock it up with some offset lifters. Should cure that. I'm using a the Comp Cams # 892 .180 offset lifters in this build It is a low deck 400 block.
[Re: Cab_Burge]
#1994950
01/20/16 03:58 PM
01/20/16 03:58 PM
Posts: 368 michigan
turbo toad
michigan
Please dont take this the wrong way but were the lifters put it the correct bore intake in intake bore exhaust in the exhaust bore Just throwing it out there
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: Cab_Burge]
#1995029
01/20/16 05:22 PM
01/20/16 05:22 PM
Jerry Kathe
Mock it up with some offset lifters. Should cure that. I'm using a the Comp Cams # 892 .180 offset lifters in this build It is a low deck 400 block. This is where I would have to bow out. No experience with a low deck (the worst of pushrod angle) and 7/16 diameter PR's and the indy head. If you have the wall thickness....grab the die grinder - lol
