440-1 heaads with Jesel rockers ,pushrod rubbng problems #1994455
01/19/16 11:03 PM
01/19/16 11:03 PM
Cab_Burge Offline OP
I'm mocking up a 400 block bracket motor with a set of 440-1 heads I bought off of a member on here in the past,I'm having pushrod rubbing problems on two intake port runners(#1 and #7) on the drivers side using 7/16 O.D. pushrods with the Jesel 1.55 ratio paired rocker arms. I did swap those two pushrods to a smaller 3/8 diameter and they didn't rub when on the heel of the cam but they did hit at mid to max lift runaway I haven't mock up the other side up yet so I don't know if they will hit on that side also, my question is, is this common help
All input apreciated thumbs
Re: 440-1 heaads with Jesel rockers ,pushrod rubbng problems [Re: Cab_Burge] #1994633
01/20/16 01:57 AM
01/20/16 01:57 AM
canada
gazoo Offline
gazoo  Offline
canada
Happened on my ez heads with 1.6 hughes rockers.Had to grind for clearance till I actually hit intake port.Got mad bought 440-1s with 1.55 jesels which should have helped in the clearance department. Still had to grind for clearance.By the way lifter bores were jigged and bushed. Buddy at the time did a 451 no clearance issues at all.Likely just a bad case of core shift.
Re: 440-1 heaads with Jesel rockers ,pushrod rubbng problems [Re: gazoo] #1994724
01/20/16 04:48 AM
01/20/16 04:48 AM
I will find out tomorrow if the other head has the same problems or not. I thought it was odd that the two end intake runner hit the pushrods and the middle two didn't confused
Thanks up
Re: 440-1 heaads with Jesel rockers ,pushrod rubbng problems [Re: Cab_Burge] #1994735
01/20/16 09:08 AM
01/20/16 09:08 AM
Jerry Kathe Offline
Jerry Kathe  Offline
Mock it up with some offset lifters. Should cure that.
Re: 440-1 heaads with Jesel rockers ,pushrod rubbng problems [Re: Cab_Burge] #1994736
01/20/16 09:16 AM
01/20/16 09:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run paired T&D 1.7. With off set lifters and 7/16" push rods. A small amount of grinding was necessary on the intake port wall. I run very little clearance, no more than .060".No issues after 300 passes.
Doug
Re: 440-1 heaads with Jesel rockers ,pushrod rubbng problems [Re: Cab_Burge] #1994777
01/20/16 11:23 AM
01/20/16 11:23 AM
gregsdart Online content
gregsdart  Online Content
Jesel 1.55 rockers here, same trouble with clearance. I run offset lifters already, still needed more room for 7/16 or bigger pushrods.
Re: 440-1 heaads with Jesel rockers ,pushrod rubbng problems [Re: gregsdart] #1994808
01/20/16 12:14 PM
01/20/16 12:14 PM
Jerry Kathe Offline
Jerry Kathe  Offline
Originally Posted By gregsdart
Jesel 1.55 rockers here, same trouble with clearance. I run offset lifters already, still needed more roofom for 7/16 or bigger pushrods.
Low deck?
Re: 440-1 heaads with Jesel rockers ,pushrod rubbng problems [Re: Jerry Kathe] #1994827
01/20/16 12:46 PM
01/20/16 12:46 PM
Low deck?
Megablock
Re: 440-1 heaads with Jesel rockers ,pushrod rubbng problems [Re: Cab_Burge] #1994866
01/20/16 01:43 PM
01/20/16 01:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
FWIW my 3/8 p-rods rub slightly on my rpm heads and figured it was a built in guide plate............. realcrazy Many years later and same p-rods w/zero issues........... drive
Re: 440-1 heaads with Jesel rockers ,pushrod rubbng problems [Re: Jerry Kathe] #1994937
01/20/16 03:30 PM
01/20/16 03:30 PM
I'm using a the Comp Cams # 892 .180 offset lifters in this build up It is a low deck 400 block.
Re: 440-1 heaads with Jesel rockers ,pushrod rubbng problems [Re: Cab_Burge] #1994950
01/20/16 03:58 PM
01/20/16 03:58 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Please dont take this the wrong way but were the lifters put it the correct bore intake in intake bore exhaust in the exhaust bore
Just throwing it out there
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: 440-1 heaads with Jesel rockers ,pushrod rubbng problems [Re: turbo toad] #1994962
01/20/16 04:09 PM
01/20/16 04:09 PM
up grin I have probally made every mistake there is to make on motors, maybe even some that no one else has found yet whistling work grin
If you don't test new parts or try doing things differently you usually won't make mistakes whistling shruggy
Not that I like finding out new ways to mess things up shruggy
That is why I, we post on here asking for help, correct work
Re: 440-1 heaads with Jesel rockers ,pushrod rubbng problems [Re: Cab_Burge] #1995029
01/20/16 05:22 PM
01/20/16 05:22 PM
Jerry Kathe Offline
Jerry Kathe  Offline
This is where I would have to bow out. No experience with a low deck (the worst of pushrod angle) and 7/16 diameter PR's and the indy head. If you have the wall thickness....grab the die grinder - lol
Re: 440-1 heaads with Jesel rockers ,pushrod rubbng problems [Re: Jerry Kathe] #1995363
01/21/16 03:46 AM
01/21/16 03:46 AM
canada
gazoo Offline
gazoo  Offline
canada
Also note my jesel 1.55 also needed clearancing on the pushrod side of rocker when using indy cast valve cover with spray bar oiling. Feel along valve cover when running you'll know right away.
