Re: Driving the 37 and lost a wheel
[Re: OzHemi]
#1994623
01/20/16 01:43 AM
01/20/16 01:43 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
PS, not sure if it bothers you or not, but you can get little snap in chrome caps to fill the extra 5 holes from the 5 on 4 3/4" bolt pattern too.. Where do I get those at?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: moparx]
#1994784
01/20/16 11:30 AM
01/20/16 11:30 AM
AZ_A12_BEE
Dreaming of the 808
wasn't so bad after all was it ? i can assume you rotated the assembly after installation to make sure nothing [the bolt head] hit internally ? the bolt heads shouldn't have been any higher than the rivet heads, but you never know. check the bolts aren't backing out the next couple of times you have the tire/wheel off for what ever reason just to make sure. enjoy your new wheel combo ! [looks good by the way ! ] the old slots may be salvageable by using a reamer of the correct size to fit the shank style lugs that were intended for them, or someone could make them into a "10 bolt"[4 3/4" GM pattern] wheel.now continue to use the truck to haul materials for your shop renovation ! keep us up to date on that project too ! e No rotating issues with the bolt heads, the shouldn't back out, I used red Loctite on them before torquing them down
37 Plymouth PU
[Re: Supercuda]
#1997409
01/24/16 12:17 AM
01/24/16 12:17 AM
AZ_A12_BEE
Dreaming of the 808
Better pics of the new wheels taken today
37 Plymouth PU
[Re: AZ_A12_BEE]
#1997459
01/24/16 01:33 AM
01/24/16 01:33 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
About .20 less around here
[Re: Supercuda]
#1997475
01/24/16 01:58 AM
01/24/16 01:58 AM
moparpollack
Lil Herman
Lil Herman
85086
About an additional .20 less here. Filled up the challenger with 91 octane for $26.00.
[Re: OzHemi]
#1997492
01/24/16 02:22 AM
01/24/16 02:22 AM
moparpollack
Lil Herman
Lil Herman
85086
About an additional .20 less here. Filled up the challenger with 91 octane for $26.00. $2.50 - $2.70 here for the cheap stuff.. $1.31- 87 $1.61 here for 91
