What is everyone running for front drive set ups on a BBM? #1991966
01/16/16 02:29 PM
01/16/16 02:29 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Just curious to see what everyone is running for front drive set up on a Big Block Mopar/HEMI with a front plate & vacuum pumps? I currently have the electric Mezeire water pump motor in the stock aluminum water pump housing. Just need to come up with something to drive the alternator & vacuum pump.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1991972
01/16/16 02:36 PM
01/16/16 02:36 PM
AndyF Online content
AndyF  Online Content
You can build any sort of pulley arrangement off the damper by using a mandral.
Re: What is everyone running for front drive set ups on a BBM? [Re: AndyF] #1991977
01/16/16 02:38 PM
01/16/16 02:38 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Who's mandrel or set up is that?
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1991982
01/16/16 02:46 PM
01/16/16 02:46 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I would bet it is something Andy F Makes. He makes most of his stuff.
Jerry
Old Geezer Racing
Re: What is everyone running for front drive set ups on a BBM? [Re: SCATPACK 1] #1992002
01/16/16 03:16 PM
01/16/16 03:16 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
That pic answers my question about how the mandrel and crank trigger go's together. thumbs
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1992061
01/16/16 05:02 PM
01/16/16 05:02 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
GZ pump and bracket. Welded a boss on the Meziere pump for the alternator. A slot was cut in the motor plate for at belt adjustment.
Doug
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1992135
01/16/16 07:37 PM
01/16/16 07:37 PM
I think it is a Petersen BBC drive kit that I modified to work on a Mopar.
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1992142
01/16/16 07:46 PM
01/16/16 07:46 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My mandrel is GZ.
Doug
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1992166
01/16/16 08:17 PM
01/16/16 08:17 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
home made pulley, home made mandrel here.
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1992175
01/16/16 08:32 PM
01/16/16 08:32 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I use Peterson Spline drive front drives
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1992241
01/16/16 10:35 PM
01/16/16 10:35 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Hopefully, your damper has a Chevy bolt pattern in the front. If so the choices of NICE front drives is endless. Personally, I HATE the mandrels that just thread in the end of the crank. You can't turn the motor with them vs the 3 bolt mandrel, that is anchored to balancer and has the option on the front of mandrel to turn motor. I typically use a Star Machine drive
Re: What is everyone running for front drive set ups on a BBM? [Re: Monte_Smith] #1992258
01/16/16 10:57 PM
01/16/16 10:57 PM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
Star machine
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1992261
01/16/16 10:58 PM
01/16/16 10:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I turn mine with the crank bolt, no issue.
Doug
Re: What is everyone running for front drive set ups on a BBM? [Re: Monte_Smith] #1992265
01/16/16 11:03 PM
01/16/16 11:03 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I made one for my friends Big Block, I didn't allow for the engine to be turned over, so I will be making it again with a drive in the front.
Alan Jones
Re: What is everyone running for front drive set ups on a BBM? [Re: dvw] #1992296
01/16/16 11:39 PM
01/16/16 11:39 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Doug
What keeps the crank bolt from backing out if you try and turn motor backwards
Re: What is everyone running for front drive set ups on a BBM? [Re: Monte_Smith] #1992431
01/17/16 08:51 AM
01/17/16 08:51 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
I don't turn it backwards. Always taught the Jessel belt should only go forward. Haven't had a need to turn it backward. Not sure if the engine rotational break away torque would exceed the break away torque of the crank bolt. It would have to exceed 135lb/ft.
Doug
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1992474
01/17/16 12:05 PM
01/17/16 12:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I got all my parts for the front drive from CV Products
which is a roundy round company
http://www.cvproducts.com/
wave
Re: What is everyone running for front drive set ups on a BBM? [Re: MR_P_BODY] #1992562
01/17/16 02:21 PM
01/17/16 02:21 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I agree 100% with using a chevy pattern front on your balancer. One issue it creates with some of the drives it attachment due to the size of the bolt and the way the balancer sits in a BB Mopar. We modified my Peterson to work with a stock bolt and washer set up. Or they sell spacers to go between the hub of the spline drive and balancer. We did not like the way the spacer looked so just modify the spline drive hub to work with no spacer
image_zpsrkqhhv0u.JPEGimage_zpshs9jyz7r.JPEGimage_zpswu5xxgip.JPEGimage_zpsmunuqgrh.JPEG
Re: What is everyone running for front drive set ups on a BBM? [Re: Al_Alguire] #1992568
01/17/16 02:23 PM
01/17/16 02:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Hopefully makes sense. We use an ARP washer, cut down grade 8 bolt and then machine the back of the drive hub. All because we did not want to run a spacer smile
Re: What is everyone running for front drive set ups on a BBM? [Re: 6PKRTSE] #1992691
01/17/16 04:10 PM
01/17/16 04:10 PM
Al, it is a little less work to buy the extra thick BBC spline drive blank from Peterson. They sell one that call a blank but it is mostly machined already, just extra thick. It clears the Mopar bolt.
