What is everyone running for front drive set ups on a BBM?
#1991966
01/16/16 02:29 PM
01/16/16 02:29 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Just curious to see what everyone is running for front drive set up on a Big Block Mopar/HEMI with a front plate & vacuum pumps? I currently have the electric Mezeire water pump motor in the stock aluminum water pump housing. Just need to come up with something to drive the alternator & vacuum pump.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: What is everyone running for front drive set ups on a BBM?
[Re: AndyF]
#1991977
01/16/16 02:38 PM
01/16/16 02:38 PM
6PKRTSE
Motor City
Who's mandrel or set up is that?
[Re: 6PKRTSE]
#1991982
01/16/16 02:46 PM
01/16/16 02:46 PM
Posts: 1,505 TN
SCATPACK 1
TN
Who's mandrel or set up is that? I would bet it is something Andy F Makes. He makes most of his stuff. Jerry
Old Geezer Racing
[Re: 6PKRTSE]
#1992135
01/16/16 07:37 PM
01/16/16 07:37 PM
Posts: 31,023 Oregon
AndyF
Who's mandrel or set up is that? I think it is a Petersen BBC drive kit that I modified to work on a Mopar.
[Re: 6PKRTSE]
#1992142
01/16/16 07:46 PM
01/16/16 07:46 PM
Posts: 9,835 MI, usa
dvw
MI, usa
[Re: 6PKRTSE]
#1992175
01/16/16 08:32 PM
01/16/16 08:32 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
I use Peterson Spline drive front drives
[Re: Monte_Smith]
#1992265
01/16/16 11:03 PM
01/16/16 11:03 PM
Posts: 6,139 Melbourne , Australia
LA360
I made one for my friends Big Block, I didn't allow for the engine to be turned over, so I will be making it again with a drive in the front.
Alan Jones
[Re: dvw]
#1992296
01/16/16 11:39 PM
01/16/16 11:39 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I turn mine with the crank bolt, no issue. Doug What keeps the crank bolt from backing out if you try and turn motor backwards
[Re: Monte_Smith]
#1992431
01/17/16 08:51 AM
01/17/16 08:51 AM
dvw
MI, usa
I turn mine with the crank bolt, no issue. Doug What keeps the crank bolt from backing out if you try and turn motor backwards I don't turn it backwards. Always taught the Jessel belt should only go forward. Haven't had a need to turn it backward. Not sure if the engine rotational break away torque would exceed the break away torque of the crank bolt. It would have to exceed 135lb/ft. Doug
[Re: 6PKRTSE]
#1992474
01/17/16 12:05 PM
01/17/16 12:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I got all my parts for the front drive from CV Products which is a roundy round company http://www.cvproducts.com/
[Re: MR_P_BODY]
#1992562
01/17/16 02:21 PM
01/17/16 02:21 PM
Al_Alguire
Las Vegas
I agree 100% with using a chevy pattern front on your balancer. One issue it creates with some of the drives it attachment due to the size of the bolt and the way the balancer sits in a BB Mopar. We modified my Peterson to work with a stock bolt and washer set up. Or they sell spacers to go between the hub of the spline drive and balancer. We did not like the way the spacer looked so just modify the spline drive hub to work with no spacer
