Cherry Picker #1989634
01/13/16 12:40 AM
01/13/16 12:40 AM
W
Wagonman1967 Offline OP
W
I want to stab the 440-727 at the same time.Will one of the Hobo Freight 2 ton pickers set on the 1/2 ton setting handle the weight? Any body done it?
1968 Bronze Metalic Road Runner
!967 Malibu Wagon Original 4sd w/air
2001 Dodge Ram 4wd
1985 GMC K1500 4in lift
1993 Honda Civic W 350k Beater
2003 Honda VTX 1800 Bagger
Re: Cherry Picker [Re: Wagonman1967] #1989693
01/13/16 02:04 AM
01/13/16 02:04 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I had no trouble stabbing a 360-727 combo in a D100 truck with one of their fold up pickers.
Re: Cherry Picker [Re: Wagonman1967] #1989782
01/13/16 11:43 AM
01/13/16 11:43 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I did my 440, 727, k-frame, complete front suspension with tires still attached and there was no issue.
Re: Cherry Picker [Re: DaytonaTurbo] #1989796
01/13/16 12:10 PM
01/13/16 12:10 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Same here, but the rams only last a couple of years before you have to buy a new one, or try to put new seals in it... eyes
JB Rhinehart, Realist
A-Body's RULE!
Re: Cherry Picker [Re: Wagonman1967] #1989950
01/13/16 04:00 PM
01/13/16 04:00 PM
W
W
Thanks I will give it a whirl.
2001 Dodge Ram 4wd
Re: Cherry Picker [Re: Wagonman1967] #1990362
01/14/16 01:33 AM
01/14/16 01:33 AM
Waterloo Iowa
8
80mirada Offline
80mirada  Offline
Waterloo Iowa
Run the ram all the wat up and clean it with a soft rag and wd40 or jack oil usually helps the seals last longer. Mine has done it no problem.
Re: Cherry Picker [Re: 80mirada] #1990655
01/14/16 03:12 PM
01/14/16 03:12 PM
dogdays Offline
dogdays  Offline
My ram has lasted since 1984. Occasionally I forget and leave it up, then have to scour the rust off but it still works. Maybe a hydraulic supply house could get you a better seal?
R.
Re: Cherry Picker [Re: dogdays] #1991015
01/15/16 12:30 AM
01/15/16 12:30 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Most of the hydraulic 8-ton long rams that I have seen are made in China and therefore disposable.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
