Re: Cost of 900 hp in a N/A small block?
[Re: LSP]
#1963995
12/05/15 08:59 PM
12/05/15 08:59 PM
Posts: 11,726 Portage,michigan
B3422W5
Portage,michigan
What kind of hp does 164.50mph at 2860 lbs. with an automatic equate to? Mighty close to 1000
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30โs 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: B3422W5]
#1963998
12/05/15 09:03 PM
12/05/15 09:03 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Wallace Racing calculator says 1019 hp.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: 408strokerdart]
#1964024
12/05/15 10:20 PM
12/05/15 10:20 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
What does Al Carps FS/B Challenger weigh? 3200? It holds the FS/B record with a 8.54 @ 157. 426 Gen III. Ray said something about NHRA only allowing .675 lift at the valve too lol.
Mopar to the bone!!!
#1964062
12/05/15 11:37 PM
12/05/15 11:37 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
FS/B: ยท Index: 10.35 ยท Naturally Aspirated entries only o Entries up to 400 CID must weigh a minimum of 3,250 lbs. o Entries up to 430 CID must weigh a minimum of 3,350 lbs.
that was August 2014....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1987143
01/09/16 09:13 PM
01/09/16 09:13 PM
Posts: 1,784 PA
W5DART66
PA
My w8 engine on dyno today. Cast intake one 1250 carb. 411 CI My other w8 engine is from engine masters 2011 Made 750 Hp on this same dyno and has been 8.90s 150mph at 2915lbs ๐๐ป
#1987234
01/09/16 11:37 PM
01/09/16 11:37 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Had a really good time today, could have made another dozen pulls on it changing stuff. Congrats Brett that is one seriously mean wedge you built.
Brett Miller W9 cnc'd heads STR Chassis fabraction
#1987272
01/10/16 12:43 AM
01/10/16 12:43 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Awesome Brett, so what would the engine cost?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1987284
01/10/16 12:54 AM
01/10/16 12:54 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
BIG dollars but it costs a lot less when you do the work yourself and sure gives you a good feeling in your belly. I'm not big on DYNO numbers but even unfactored numbers got to be sky high. GREAT job Brett. I think Josh (monster Mopar) better start closing the giveaways to these small blocks. They are great engines with heads flowing better or very close to all the available big block heads.
