Page 9 of 12 1 2 7 8 9 10 11 12
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1958685
11/27/15 06:53 AM
11/27/15 06:53 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Jesel or Westcott can supply any kind of cam core you'd need. If 900hp on most dynos with a N/A 400" R5/P7 is the goal, it wouldn't be difficult and could be done on somewhat of a budget. Getting 1100hp+ with a N/A 400" R5/P7 will get spendy, no different than doing the same thing with a SBC. A current new competitive Comp Elim. small block fetches 100k-125k, depending on who you write the check to.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1963899
12/05/15 06:53 PM
12/05/15 06:53 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
What kind of hp does 164.50mph at 2860 lbs. with an automatic equate to?
Re: Cost of 900 hp in a N/A small block? [Re: LSP] #1963995
12/05/15 08:59 PM
12/05/15 08:59 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Mighty close to 1000
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Cost of 900 hp in a N/A small block? [Re: B3422W5] #1963998
12/05/15 09:03 PM
12/05/15 09:03 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Wallace Racing calculator says 1019 hp.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1964024
12/05/15 10:20 PM
12/05/15 10:20 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
What does Al Carps FS/B Challenger weigh? 3200? It holds the FS/B record with a 8.54 @ 157. 426 Gen III. Ray said something about NHRA only allowing .675 lift at the valve too lol.
Mopar to the bone!!!
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1964062
12/05/15 11:37 PM
12/05/15 11:37 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
FS/B:
ยท Index: 10.35
ยท Naturally Aspirated entries only
o Entries up to 400 CID must weigh a minimum of 3,250 lbs.
o Entries up to 430 CID must weigh a minimum of 3,350 lbs.
that was August 2014....
Tony
70 AARCuda Vitamin C
Re: Cost of 900 hp in a N/A small block? [Re: 70AARcuda] #1987143
01/09/16 09:13 PM
01/09/16 09:13 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
My w8 engine on dyno today.
Cast intake one 1250 carb.
411 CI
My other w8 engine is from engine masters 2011
Made 750 Hp on this same dyno and has been 8.90s 150mph at 2915lbs
๐Ÿ‘๐Ÿป
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1987165
01/09/16 09:37 PM
01/09/16 09:37 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
HELL YEAH!! VERY IMPRESSIVE!!
Re: Cost of 900 hp in a N/A small block? [Re: W5DART66] #1987173
01/09/16 09:45 PM
01/09/16 09:45 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
bow
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1987234
01/09/16 11:37 PM
01/09/16 11:37 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Had a really good time today, could have made another dozen pulls on it changing stuff. Congrats Brett that is one seriously mean wedge you built.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Cost of 900 hp in a N/A small block? [Re: 1967dartgt] #1987248
01/10/16 12:03 AM
01/10/16 12:03 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Yes big thanks to Brad Tory and Brandon
For the help today
Thanks Rider race engines for letting me sneak in on the dyno๐Ÿ‘๐Ÿป
Re: Cost of 900 hp in a N/A small block? [Re: W5DART66] #1987251
01/10/16 12:05 AM
01/10/16 12:05 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
And now the chassis tuning begins biggrin
Glad to see it is off the Dyno and happy, and making power bow
"Just a Bracket car dressed up like a streetcar"
Re: Cost of 900 hp in a N/A small block? [Re: Just-a-dart] #1987260
01/10/16 12:21 AM
01/10/16 12:21 AM
oregon
greendart408 Offline
oregon
All the time and dedication shows....... Nice work
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1987272
01/10/16 12:43 AM
01/10/16 12:43 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Awesome Brett, so what would the engine cost?
Re: Cost of 900 hp in a N/A small block? [Re: sixpackgut] #1987284
01/10/16 12:54 AM
01/10/16 12:54 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
BIG dollars but it costs a lot less when you do the work yourself and sure gives you a good feeling in your belly. I'm not big on DYNO numbers but even unfactored numbers got to be sky high. GREAT job Brett. I think Josh (monster Mopar) better start closing the giveaways to these small blocks. They are great engines with heads flowing better or very close to all the available big block heads.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1987292
01/10/16 01:06 AM
01/10/16 01:06 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I can't give a price,but I can give advice..Brett shared every single detail and looked for better prices which is way above and beyond while doing my engine.
Great job Brett I'm happy you finally got yours done.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1987306
01/10/16 01:34 AM
01/10/16 01:34 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
shots fired!! shots fired!! laugh2 can't wait to see the "in car" performance this spring!
Re: Cost of 900 hp in a N/A small block? [Re: J_BODY] #1987435
01/10/16 10:54 AM
01/10/16 10:54 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
I don't know what I have in this engine.
Don't want to know lol
But you do not need some of the spendy stuff that's in this engine to make. The power.
I think it could be done for $28000-30000 for all new parts.
Shop around take your time I think it can be done for $15000-20000 with the right used parts.
The best way is used w8 top end as most of it out in the world is way to small for drag race engine.
So it's easy to fix them right up๐Ÿ˜œ
Re: Cost of 900 hp in a N/A small block? [Re: W5DART66] #1987461
01/10/16 12:11 PM
01/10/16 12:11 PM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
Re: Cost of 900 hp in a N/A small block? [Re: W5DART66] #1987479
01/10/16 12:50 PM
01/10/16 12:50 PM
Ohio, United States
BuckeyeBrawler Offline
Ohio, United States
bow Now thar's awesome! Nice job !
