Electronic Distributor I.D. #1985976
01/08/16 12:28 AM
01/08/16 12:28 AM
michigan
440whiteboy Offline OP
michigan
I have purchased this a few years ago, misplaced the receipt.
It may be late 70's - 80's for
383?
part # 3755681
I plan to offer it for sale.
Thanks in advance -
They only see Stars...
when hit by a Mopar!
Re: Electronic Distributor I.D. [Re: 440whiteboy] #1986053
01/08/16 02:17 AM
01/08/16 02:17 AM
I'd Google the # to try & get the app (year(s)/what eng) so you could possibly sell it to someone doing a resto. If no go then sell it as NIB 70's basic electronic dist. If G does not tell you the CID then measure the lower shaft length from tang tip up to underside of round mounting flange. iirc the lengths are 3.5" 3&7/8" and 4" (B LA RB likely not in order) & the can orientation as you know would pin it to BB or SB
Re: Electronic Distributor I.D. [Re: 440whiteboy] #1986066
01/08/16 02:34 AM
01/08/16 02:34 AM
Iowa
dsp Offline
dsp  Offline
Iowa
1974 400 (R,W,P,D,C, w/o H/Perf)
Re: Electronic Distributor I.D. [Re: dsp] #1986070
01/08/16 02:37 AM
01/08/16 02:37 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
x2
Re: Electronic Distributor I.D. [Re: 440whiteboy] #1986927
01/09/16 03:20 PM
01/09/16 03:20 PM
michigan
michigan
Thank you for the info!
bottom of flange to bottom of tang shaft 3 1/2"
will list it as 74 400
