Electronic Distributor I.D.
#1985976
01/08/16 12:28 AM
01/08/16 12:28 AM
Posts: 1,106 michigan
440whiteboy
michigan
I have purchased this a few years ago, misplaced the receipt. It may be late 70's - 80's for 383?
part # 3755681
I plan to offer it for sale.
Thanks in advance -
They only see Stars... when hit by a Mopar!
Re: Electronic Distributor I.D.
[Re: 440whiteboy]
#1986053
01/08/16 02:17 AM
01/08/16 02:17 AM
RapidRobert
I'd Google the # to try & get the app (year(s)/what eng) so you could possibly sell it to someone doing a resto. If no go then sell it as NIB 70's basic electronic dist. If G does not tell you the CID then measure the lower shaft length from tang tip up to underside of round mounting flange. iirc the lengths are 3.5" 3&7/8" and 4" (B LA RB likely not in order) & the can orientation as you know would pin it to BB or SB
[Re: dsp]
#1986070
01/08/16 02:37 AM
01/08/16 02:37 AM
Posts: 623 Zombieland
Car Nut
Zombieland
1974 400 (R,W,P,D,C, w/o H/Perf) x2
[Re: 440whiteboy]
#1986927
01/09/16 03:20 PM
01/09/16 03:20 PM
440whiteboy
michigan
Thank you for the info!
bottom of flange to bottom of tang shaft 3 1/2"
will list it as 74 400
