Re: Fenders
[Re: mopardamo]
#1982941
01/03/16 07:47 PM
01/03/16 07:47 PM
moparpollack
Lil Herman
Lil Herman
85086
Re: Fenders
[Re: dangina]
#1983091
01/03/16 10:42 PM
01/03/16 10:42 PM
Posts: 22,696 Bitopia
jcc
Bitopia
that's an interesting build, thanks
Re: Fenders
[Re: OzHemi]
#1983103
01/03/16 10:57 PM
01/03/16 10:57 PM
moparpollack
Lil Herman
Lil Herman
85086
Bushwackers!
Re: Fenders
[Re: OzHemi]
#1983113
01/03/16 11:11 PM
01/03/16 11:11 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Then his steering wheel would be on the wrong side....
Mopar to the bone!!!
Re: Fenders
[Re: mopardamo]
#1984316
01/05/16 05:59 PM
01/05/16 05:59 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
The front fenders are easy to modify: get rid of the upper cross bar if still present... roll/fold/flush the lips (only needed at the top for about 24 inches at most)... begin pulling the fenders out by hand... result is an easy 1-2 inch gain per side. Both fronts can be done in one evening.
The rears can also be modified... but you need to be more willing to do this: first, make a few metal cuts along the top sections of the lips on the inside (you can also cut at the spot welds)... then roll/fold/flush the lips... then tug-pull the fenders out as you need... then reweld the cuts, epoxy the inside areas that have been cut... nice and smooth. You can gain an easy 1-2-3 inches pending how much you pull. Each rear fender can be done in one evening.. two evenings total for the rears.
Best of all... you'll still have the outer lips appearing stock... you could even reattach the factory chrome moldings (and flush them as needed)... if you really wanted to (but.. who needs them?... don't bother with them).
Also, its probably best to have your rims/tires mounted on the car so to make the actual fender mods as you need... in other words, no need to go extreme if you don't need to.
My best friend owns a body shop and he did these mods for me ~30 years ago... they appear stock and unless you have another stock fendered car next to it, the difference is hard to tell. This was for my then 255-50-16 Hoosiers mounted on 16x10 rims (f/r) having 5" backspace (actually pushing out ~1/2 inch towards the fenders). Later, I changed tire sizes to Hoosier 275-45-16... slightly wider, but also slighter lower in overall diameter. The fit is perfect, no scrubbing or rubbing, even under hard g-force when autocrossing... a pinky-finger can barely fit between the tires and fender lips... stiff suspension also is helpful preventing excessive lift/dive/lean in extreme g-force situations.
The only down-side is when you put smaller width rims/tires onto the car, then... the fenders look empty (example: 15x8 rims f/r 255-60 f, 275-60 r BFG T/As used for street/hwy cruising, and also my 16x8 rims f/r with 255-50 BFG G-Force Copmp T/As used for HSAX/HPDE lapping road course events. Eventually, I'll be running the Hoosier A or R 6 or 7 series 275-45-16 race tires again.... maybe, and probably, as well, getting a set of 18x10 or 11" wide f/r rims with at least 275-35-18 200 TW tires.. or maybe a bit wider.
There's really no need for big flares unless you have to have them or want them!
MoPower to ya!
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
Re: Fenders
[Re: geo.]
#1987262
01/10/16 12:25 AM
01/10/16 12:25 AM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
I didn't see this in Brads fender build, anyone know if the fender gained or lost weight with the beautiful flare job? I'm sure they added weight to the car over the stock fenders. I wouldn't guess it added a lot? I never did weight them.
