Re: Big block A-body guy's
[Re: dartman366]
#1984179
01/05/16 03:08 PM
01/05/16 03:08 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I loved my Headman fender wells. shortish 2" tubes and long collector. I know that's not what you want but I think you should consider
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: JACK1440]
#1984194
01/05/16 03:29 PM
01/05/16 03:29 PM
dartman366
Mt. Vernon, Ohio
We ran McCandles (Pro Parts) for years. I really liked them but, they do have 1 tube outside the frame on one side and 2 on the other. thats not an issue as my Hedman smallblock header's have a single tube that is on the outside on each side.
[Re: FastmOp]
#1984340
01/05/16 06:27 PM
01/05/16 06:27 PM
Thumperdart
State of confusion
I ran fenderwell supercomps for years and finally built a set of custom fenderwell headers in 2.250 Did you test to see the power diff?
[Re: FastmOp]
#1984381
01/05/16 07:20 PM
01/05/16 07:20 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
No way I'd have in chassis headers on a big block a body that still had torsion bars. Been real happy with hookers on a 470 with Indy heads. Easy to work on and easy to take off. However I would like to see a set of in chassis headers on a big block a body without torsion bars.
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: mikeysmopars]
#1984386
01/05/16 07:29 PM
01/05/16 07:29 PM
dartman366
Mt. Vernon, Ohio
No way I'd have in chassis headers on a big block a body that still had torsion bars. Been real happy with hookers on a 470 with Indy heads. Easy to work on and easy to take off. However I would like to see a set of in chassis headers on a big block a body without torsion bars. no torsion bars here, took them off a long time ago and switched to coilovers,no motormounts either have front plate, still have stock K member with Cap auto upper and lower controll arms but still have stock steering,,but thats another post.
[Re: dartman366]
#1984439
01/05/16 08:49 PM
01/05/16 08:49 PM
Posts: 1,030 ohio
67mprfan
ohio
Pro-parts don't remember if I had the hood off while we were at the track or not
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: dartman366]
#1984454
01/05/16 09:16 PM
01/05/16 09:16 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Bill, in my opinion there's only one way to do it right since you don't have torsion bars or motor mounts and that is to have them custom made to fit your car. That's what I'll do next time for sure. Another option would be to find a set of TTI 2 1/8" step headers to test fit in your car.
I've used TTI 2" underchassis headers, ProParts 2" and MadDog 2" and they were all just a huge pain with torsion bars and inner fenders.
The Hedman fenderwell headers that Sixpackgut mentioned are something that I always wanted to try as they made more power than anything else on several cars that I read about.
[Re: ProSport]
#1984472
01/05/16 09:37 PM
01/05/16 09:37 PM
Posts: 1,030 ohio
67mprfan
ohio
If you run the hedman fender well headers don't you also run into tire clearance issues where a taller tire will hit plus you can't make Sharp turns without them rubbing. I'm not sure just asking
[Re: dartman366]
#1984497
01/05/16 10:23 PM
01/05/16 10:23 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
What headers are you running? I want to run the between the frame rail's style but don't see many options other than TTI or making them,,pic's and link's if you got them. If I remember right,,you don't have inner fender panels. The TTI's are CLOSE to just about anything. Not having inner fenders and no torsion bars would be a big +. You know my car,,all original front suspension/torsion bars/steering/inner fender wells/etc......it takes 4 hours to get the starter off and 4 hours to get it back on with the TTI's. Mine is an RB with Indy EZ-1 heads,,,your low block 'may' be better or worse. You ain't gonna' like the extra work/time involved with an A body/B/RB engine combination!! You'll enjoy the power, but the work required in routine maintenance is making me want to go back to a B body car.
If you like drag racing, support your local track.
