Page 1 of 3 1 2 3
Big block A-body guy's #1984161
01/05/16 02:33 PM
01/05/16 02:33 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
What headers are you running? I want to run the between the frame rail's style but don't see many options other than TTI or making them,,pic's and link's if you got them. wave
Re: Big block A-body guy's [Re: dartman366] #1984176
01/05/16 02:58 PM
01/05/16 02:58 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
I have had the TTI headers - they fit - but man you need a box of band-aids and a 12 pack to install
I have heard the Pro-Parts fit - but hang low
Their was one other - but I cant recall - ProSport might know
Re: Big block A-body guy's [Re: dartman366] #1984179
01/05/16 03:08 PM
01/05/16 03:08 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I loved my Headman fender wells. shortish 2" tubes and long collector. I know that's not what you want but I think you should consider
Re: Big block A-body guy's [Re: dartman366] #1984188
01/05/16 03:21 PM
01/05/16 03:21 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Dont have them and never saw a set in real life but here is another option.
http://www.maddogheaders.net/products/mopar
Re: Big block A-body guy's [Re: dartman366] #1984190
01/05/16 03:22 PM
01/05/16 03:22 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
We ran McCandles (Pro Parts) for years. I really liked them but, they do have 1 tube outside the frame on one side and 2 on the other.
Re: Big block A-body guy's [Re: dartman366] #1984191
01/05/16 03:25 PM
01/05/16 03:25 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We make them smile
Re: Big block A-body guy's [Re: JACK1440] #1984194
01/05/16 03:29 PM
01/05/16 03:29 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
thats not an issue as my Hedman smallblock header's have a single tube that is on the outside on each side.
Re: Big block A-body guy's [Re: dartman366] #1984196
01/05/16 03:30 PM
01/05/16 03:30 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I ran fenderwell supercomps for years and finally built a set of custom fenderwell headers in 2.250
Re: Big block A-body guy's [Re: dartman366] #1984241
01/05/16 04:20 PM
01/05/16 04:20 PM
You have a PM on this scope
Re: Big block A-body guy's [Re: FastmOp] #1984340
01/05/16 06:27 PM
01/05/16 06:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Did you test to see the power diff?
Re: Big block A-body guy's [Re: dartman366] #1984347
01/05/16 06:39 PM
01/05/16 06:39 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
http://www.bobmazzoliniracing.com/shop#!/A-Body/c/4308142/offset=0&sort=normal
link to headers
Re: Big block A-body guy's [Re: dartman366] #1984375
01/05/16 07:03 PM
01/05/16 07:03 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Picked up .15 in the 1/8
Re: Big block A-body guy's [Re: FastmOp] #1984381
01/05/16 07:20 PM
01/05/16 07:20 PM
fresno ca
mikeysmopars Offline
fresno ca
No way I'd have in chassis headers on a big block a body that still had torsion bars. Been real happy with hookers on a 470 with Indy heads. Easy to work on and easy to take off. However I would like to see a set of in chassis headers on a big block a body without torsion bars.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Big block A-body guy's [Re: mikeysmopars] #1984386
01/05/16 07:29 PM
01/05/16 07:29 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
no torsion bars here, took them off a long time ago and switched to coilovers,no motormounts either have front plate, still have stock K member with Cap auto upper and lower controll arms but still have stock steering,,but thats another post. laugh2
Re: Big block A-body guy's [Re: dartman366] #1984427
01/05/16 08:28 PM
01/05/16 08:28 PM
ohio
67mprfan Online content
67mprfan  Online Content
ohio
Here's mine Bill .
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Big block A-body guy's [Re: 67mprfan] #1984430
01/05/16 08:33 PM
01/05/16 08:33 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Originally Posted By 67mprfan
Here's mine Bill .
which one are those?
Re: Big block A-body guy's [Re: dartman366] #1984439
01/05/16 08:49 PM
01/05/16 08:49 PM
ohio
ohio
Here's mine Bill .
Pro-parts don't remember if I had the hood off while we were at the track or not
Re: Big block A-body guy's [Re: dartman366] #1984454
01/05/16 09:16 PM
01/05/16 09:16 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Bill, in my opinion there's only one way to do it right since you don't have torsion bars or motor mounts and that is to have them custom made to fit your car. That's what I'll do next time for sure.
Another option would be to find a set of TTI 2 1/8" step headers to test fit in your car.
I've used TTI 2" underchassis headers, ProParts 2" and MadDog 2" and they were all just a huge pain with torsion bars and inner fenders.
The Hedman fenderwell headers that Sixpackgut mentioned are something that I always wanted to try as they made more power than anything else on several cars that I read about.
Re: Big block A-body guy's [Re: ProSport] #1984472
01/05/16 09:37 PM
01/05/16 09:37 PM
ohio
ohio
If you run the hedman fender well headers don't you also run into tire clearance issues where a taller tire will hit plus you can't make Sharp turns without them rubbing. I'm not sure just asking
Re: Big block A-body guy's [Re: dartman366] #1984497
01/05/16 10:23 PM
01/05/16 10:23 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
If I remember right,,you don't have inner fender panels. The TTI's are CLOSE to just about anything. Not having inner fenders and no torsion bars would be a big +. You know my car,,all original front suspension/torsion bars/steering/inner fender wells/etc......it takes 4 hours to get the starter off and 4 hours to get it back on with the TTI's. Mine is an RB with Indy EZ-1 heads,,,your low block 'may' be better or worse. You ain't gonna' like the extra work/time involved with an A body/B/RB engine combination!! You'll enjoy the power, but the work required in routine maintenance is making me want to go back to a B body car.
If you like drag racing, support your local track.
Page 1 of 3 1 2 3
