Appache Heads #1978467
12/29/15 12:01 PM
12/29/15 12:01 PM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
What have people been using for valves, springs, locks and retainers on the Appache Heads? What lifts has anyone used with stock valve train?
Max Weg
Re: Appache Heads [Re: Max Weg] #1978586
12/29/15 02:44 PM
12/29/15 02:44 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
No reason to not use the stock hollow stem valves IMO.
Mopar to the bone!!!
Re: Appache Heads [Re: Max Weg] #1978659
12/29/15 04:10 PM
12/29/15 04:10 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Re: Appache Heads [Re: Max Weg] #1978767
12/29/15 06:46 PM
12/29/15 06:46 PM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
Thanks Guys.
Max Weg
Re: Appache Heads [Re: Max Weg] #1979220
12/30/15 11:26 AM
12/30/15 11:26 AM
bonney lake washington
W
w2stroker Offline
w2stroker  Offline
W
sorry to high jack. but where can a guy find a set these days. most places i check say they are on back order.
Re: Appache Heads [Re: Max Weg] #1979285
12/30/15 01:44 PM
12/30/15 01:44 PM
Renton Washington
Triple Threat Offline
Renton Washington
I bought mine from http://www.factorymoparparts.net/
If you're planning a build with a bunch of boost you might be better off going for the new HD RAM big gas heads. 2015+ 2500 ram should have them.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Appache Heads [Re: Triple Threat] #1979668
12/30/15 09:56 PM
12/30/15 09:56 PM
Canada
onig Offline
onig  Offline
Canada
Totally agree with above statement. Actually I would buy these heads even for a NA setup, just because of the better material and beefier construction.
69 Dart
Re: Appache Heads [Re: onig] #1979680
12/30/15 10:20 PM
12/30/15 10:20 PM
W
w2stroker Offline
w2stroker  Offline
W
anyone know a part number? tried google but not having a lot of luck.not smart enough to enter the right search info lol
Re: Appache Heads [Re: Max Weg] #1979783
12/31/15 12:19 AM
12/31/15 12:19 AM
Bloomington, Illernoise
cptn60 Offline
cptn60  Offline
68238142AA pass side and 68238141AA driver side, according to the website listed above. Dont forget to add the core charge to your purchase price; it would need to be the same casting to submit and if you already had a set you wouldnt need these. $150 per side
This space available for rent
Re: Appache Heads [Re: Max Weg] #1979922
12/31/15 02:47 AM
12/31/15 02:47 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I'm suprised how cheap the Eagles are, $400 ish per according to the site listed (that's with core charge included)
Re: Appache Heads [Re: Max Weg] #1979980
12/31/15 04:53 AM
12/31/15 04:53 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Glad they came down, for a while they were more than the Apaches.
Re: Appache Heads [Re: Max Weg] #1983132
01/03/16 11:33 PM
01/03/16 11:33 PM
GA
roadrunninMark Offline
GA
Is the Eagle head better then the Apache?
Re: Appache Heads [Re: Max Weg] #1983170
01/04/16 12:21 AM
01/04/16 12:21 AM
USA
hudsonhornet7x Offline
USA
I believe that most think the Apache is a better head, but not by a whole lot.
Lots of fast guys here running eagle heads.
Re: Appache Heads [Re: Max Weg] #1983171
01/04/16 12:22 AM
01/04/16 12:22 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Apaches have bigger valves, 2.14I vs 2.055I, bigger chamber and the valves are Hollow stem (lighter). That is good stuff, but in the grand scheme of things until guys start to run cams in the .700+ realm the Eagles,6.1's and Apaches will all perform pretty equal with work done to them IMO. If building a big inch, 400+" engine, I would vote Apaches with a .600+ lift cam and some porting work. If building a big boost or nitrous engine with same size cam I would go with 6.1's or Thiteks because of valve selection and chambers would allow more piston thickness vs. compression.
Re: Appache Heads [Re: Max Weg] #1983387
01/04/16 01:29 PM
01/04/16 01:29 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Max Weg
Do not swap the hardware. The factory stuff is made by Ferea and it is their 5000 series. You'll only be going to chinese stuff if you swap it out.
Use a PAC 1220 or 1520 with a BBC spring seat with the ID opened up.
I'm using 1220 springs on my 5.7 eagle heads with a .610/.617 cam.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Appache Heads [Re: Max Weg] #1983638
01/04/16 07:47 PM
01/04/16 07:47 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
Do the eagle heads have enough meat in them to resize the throat to accommodate bigger valves?
Adriel Paradise
Substation Design Engineer III
Re: Appache Heads [Re: Adrielp] #1983839
01/04/16 11:34 PM
01/04/16 11:34 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Manley offers 2.08 valves for eagle heads, how they fit the bowl I can not answer
Re: Appache Heads [Re: 496 A-body] #1984124
01/05/16 01:29 PM
01/05/16 01:29 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
The reason I ask is because you can always use a bigger valve assuming you have the material to resize the throat in accordance with the bigger valve. If that material is there, there's not much point in getting the stock APACHE heads if the plan is to CNC port them anyways. Assuming your not going the boosted route.
Adriel Paradise
Re: Appache Heads [Re: Adrielp] #1984184
01/05/16 03:18 PM
01/05/16 03:18 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
stock Eagle valves are 2.08 I'm pretty sure. The reason to buy the Apache heads is to get a decent valve with the head already and last time I checked they were around the same price
Re: Appache Heads [Re: sixpackgut] #1984238
01/05/16 04:20 PM
01/05/16 04:20 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Stock intake valve on eagle is 2.050
Ray,having ported both eagles and apaches do you have flow numbers for both heads measured on the same bench and same bore?
