Re: Appache Heads
[Re: Max Weg]
#1978586
12/29/15 02:44 PM
12/29/15 02:44 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
No reason to not use the stock hollow stem valves IMO.
Mopar to the bone!!!
Re: Appache Heads
[Re: Triple Threat]
#1979668
12/30/15 09:56 PM
12/30/15 09:56 PM
Posts: 361 Canada
onig
Canada
I bought mine from http://www.factorymoparparts.net/If you're planning a build with a bunch of boost you might be better off going for the new HD RAM big gas heads. 2015+ 2500 ram should have them. Totally agree with above statement. Actually I would buy these heads even for a NA setup, just because of the better material and beefier construction.
69 Dart
Re: Appache Heads
[Re: Max Weg]
#1979783
12/31/15 12:19 AM
12/31/15 12:19 AM
Posts: 1,095 Bloomington, Illernoise
cptn60
68238142AA pass side and 68238141AA driver side, according to the website listed above. Dont forget to add the core charge to your purchase price; it would need to be the same casting to submit and if you already had a set you wouldnt need these. $150 per side
This space available for rent
Re: Appache Heads
[Re: Max Weg]
#1979980
12/31/15 04:53 AM
12/31/15 04:53 AM
72Swinger
Nebraska
Glad they came down, for a while they were more than the Apaches.
Re: Appache Heads
[Re: Max Weg]
#1983171
01/04/16 12:22 AM
01/04/16 12:22 AM
72Swinger
Nebraska
Apaches have bigger valves, 2.14I vs 2.055I, bigger chamber and the valves are Hollow stem (lighter). That is good stuff, but in the grand scheme of things until guys start to run cams in the .700+ realm the Eagles,6.1's and Apaches will all perform pretty equal with work done to them IMO. If building a big inch, 400+" engine, I would vote Apaches with a .600+ lift cam and some porting work. If building a big boost or nitrous engine with same size cam I would go with 6.1's or Thiteks because of valve selection and chambers would allow more piston thickness vs. compression.
Re: Appache Heads
[Re: Max Weg]
#1983387
01/04/16 01:29 PM
01/04/16 01:29 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
What have people been using for valves, springs, locks and retainers on the Appache Heads? What lifts has anyone used with stock valve train?
Max Weg Do not swap the hardware. The factory stuff is made by Ferea and it is their 5000 series. You'll only be going to chinese stuff if you swap it out. Use a PAC 1220 or 1520 with a BBC spring seat with the ID opened up. I'm using 1220 springs on my 5.7 eagle heads with a .610/.617 cam.
Re: Appache Heads
[Re: Max Weg]
#1983638
01/04/16 07:47 PM
01/04/16 07:47 PM
Posts: 577 Arkansas
Adrielp
Arkansas
Do the eagle heads have enough meat in them to resize the throat to accommodate bigger valves?
Adriel Paradise Substation Design Engineer III
Re: Appache Heads
[Re: Adrielp]
#1983839
01/04/16 11:34 PM
01/04/16 11:34 PM
Posts: 369 Indy
496 A-body
Indy
Do the eagle heads have enough meat in them to resize the throat to accommodate bigger valves? Manley offers 2.08 valves for eagle heads, how they fit the bowl I can not answer
Re: Appache Heads
[Re: 496 A-body]
#1984124
01/05/16 01:29 PM
01/05/16 01:29 PM
Posts: 577 Arkansas
Adrielp
Arkansas
Do the eagle heads have enough meat in them to resize the throat to accommodate bigger valves? Manley offers 2.08 valves for eagle heads, how they fit the bowl I can not answer The reason I ask is because you can always use a bigger valve assuming you have the material to resize the throat in accordance with the bigger valve. If that material is there, there's not much point in getting the stock APACHE heads if the plan is to CNC port them anyways. Assuming your not going the boosted route.
Re: Appache Heads
[Re: Adrielp]
#1984184
01/05/16 03:18 PM
01/05/16 03:18 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Do the eagle heads have enough meat in them to resize the throat to accommodate bigger valves? Manley offers 2.08 valves for eagle heads, how they fit the bowl I can not answer The reason I ask is because you can always use a bigger valve assuming you have the material to resize the throat in accordance with the bigger valve. If that material is there, there's not much point in getting the stock APACHE heads if the plan is to CNC port them anyways. Assuming your not going the boosted route. stock Eagle valves are 2.08 I'm pretty sure. The reason to buy the Apache heads is to get a decent valve with the head already and last time I checked they were around the same price
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
