Re: New Passon Performance 5 Speed update
[Re: JamiePasson]
#867765
12/01/10 09:17 PM
12/01/10 09:17 PM
Posts: 10,637 Rittman Ohio
fourgearsavoy
Rittman Ohio
Once again an awesome product from Passon Performance So are 1-4 in the side cover with fifth and reverse on the lower(reverse)selector shaft like a Nash/Richmond box? Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#867768
12/01/10 09:56 PM
12/01/10 09:56 PM
Posts: 23,533 Here
jcc
Here
What, no 23 spline????
Why would you do that??? They built the 18 spline because the 23 spline wouldn't hold up to the power,weight,and traction. Gus
But that was with 40? year old materials, I would think today that would be less of an issue, and Passon runs a business that caters to customer driven demands, so if there really is enough demand, why not a 23 spline in the future?
"When one’s appeal is emotional, it does not matter if there is no substance."
[Re: JamiePasson]
#867769
12/01/10 10:05 PM
12/01/10 10:05 PM
Posts: 184 Vernon Ct.
bp27
Vernon Ct.
. I really can't answer anything about the CF clutches. In my opinion, they are 2nd or 3rd choice. I never liked them. Just my opinion though. To each his own.
[Re: JamiePasson]
#867772
12/01/10 10:31 PM
12/01/10 10:31 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
We are not using an integrated shifter. If you do that, you are just gonna have another tremec that doesn't fit. It isn't a stock shifter because it is 5 speeds. It is stock arrangement. The shifter and linkage will be part of the package when the transmission is purchased. We are making a 4.35" bearing retainer and a 4.80" bearing retainer. Sorry, no 5.125 OD size. Just not enough call for one. We have an adapter ring available for the 5.125" application though.
So the front bearing will be a 307 or something similar?...or will they be tapered rollers? What rear bearing is in there?
[Re: JamiePasson]
#867776
12/01/10 11:22 PM
12/01/10 11:22 PM
Posts: 31,259 Oregon
AndyF
[Re: AndyF]
#867777
12/02/10 12:14 AM
12/02/10 12:14 AM
Posts: 6,445 Missouri
68KillerBee
Missouri
Very cool. It'll be a while before I can afford something like this, but it is awesome you came up with it. I'm sure it is well worth the wait. Just curious on weight compared to an old one? I have the 23 spline in my car and could care less if I have to change to 18 spline. It just plain makes sense to use the 18 spline. I'm sure his investment costs are already high, so maybe if these sell well he will switch, but once again, why settle for second best. Can't wait to Wonder if I'll bust my knuckles w/ my bench seat
