Page 1 of 12 1 2 3 11 12
Challenger inner fender wells....remove? #1982280
01/02/16 10:05 PM
01/02/16 10:05 PM
Parts unknown
590 Challenger Offline OP
Parts unknown
I have a 70 Challenger Stock style suspension, race only car. I have coil overs in the front tied to the 25.3 cage. Big blown Hemi. I have it down to 3,100 lbs but for my class I'm still 200 lbs over weight. Cutting the wheel wells out will give much better access, how much weight would it save? Is this advisable? Has anyone else kept the stock front frame rails and any pics?
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982344
01/02/16 11:07 PM
01/02/16 11:07 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I would....Check the crash bars in the doors...Some e-body's had them.
Re: Challenger inner fender wells....remove? [Re: Dragula] #1982461
01/03/16 01:09 AM
01/03/16 01:09 AM
Illinois
gearhead01 Offline
gearhead01  Offline
Illinois
How much do the crash bars normally weigh?
John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982472
01/03/16 01:26 AM
01/03/16 01:26 AM
Mo.
racerx Offline
racerx  Offline
Mo.
In my 73 chally when remove the bars in the door they were only bout 12 lbs. frown I no ounces ands up to pound, but it wasn't what I thought.
If I remember right 70-71 had heavier bars than the 72-74 or was it the other war around work
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982474
01/03/16 01:27 AM
01/03/16 01:27 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
If I remember correctly, it was easily 70+lbs for a pair of doors, crash bar weight.
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982476
01/03/16 01:28 AM
01/03/16 01:28 AM
Mo.
racerx Offline
racerx  Offline
Mo.
What type of stock rear suspension you run on this car? wave
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982489
01/03/16 01:51 AM
01/03/16 01:51 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
You might save 10 lbs cutting out the inner fenders. Not worth it when it comes to everything getting dirty for the front tires throwing dirt around.
69 GTX 68 Road Runner
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982501
01/03/16 02:19 AM
01/03/16 02:19 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
You need an A-body...Happy New Year Jeff!
Re: Challenger inner fender wells....remove? [Re: HardcoreB] #1982503
01/03/16 02:20 AM
01/03/16 02:20 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
He has fiberglass doors on it already...no crash bars.
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982513
01/03/16 02:46 AM
01/03/16 02:46 AM
Parts unknown
Parts unknown
Yeah, happy New Year everyone! glass doors, I was hoping for more than 10 pounds cutting out the fender wells. I still have leaf springs and Caltrac's, hoping to make some leaf spring races this year. I don't mind the dirt so much, she is track only
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982522
01/03/16 02:52 AM
01/03/16 02:52 AM
Parts unknown
Parts unknown
10 pounds is a huge help at this point
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982533
01/03/16 03:02 AM
01/03/16 03:02 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Butterfly's wide open, 590/blower, a little wrinkle, not that wide of a slick, 3100lbs and they aren't spinning? eek
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982538
01/03/16 03:06 AM
01/03/16 03:06 AM
Parts unknown
Parts unknown
315 radials, pulling 21 degrees of timing on the launch. Trying to play in the local heads up class
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982657
01/03/16 01:07 PM
01/03/16 01:07 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I don't know if it's allowed in your class, plus the expense, but changing your leaf springs to coil overs would save a lot of weight.
[image][/image]
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #1982664
01/03/16 01:15 PM
01/03/16 01:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'd cut them off and anything else that would
make it lighter and gives you more ease to get
at the engine... forget about getting dirty..
your playing on a drag strip
wave
Re: Challenger inner fender wells....remove? [Re: sgcuda] #1982667
01/03/16 01:17 PM
01/03/16 01:17 PM
Dragula Offline
Dragula  Offline
What ignition do you run with that beast?
Re: Challenger inner fender wells....remove? [Re: JERICOGTX] #1982669
01/03/16 01:23 PM
01/03/16 01:23 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Real racers don't care about a little dirt, especially heads-up racers looking for ET's and win lights. LOL
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Challenger inner fender wells....remove? [Re: sgcuda] #1982679
01/03/16 01:46 PM
01/03/16 01:46 PM
Parts unknown
Parts unknown
I can off the leafs and 4 link it for my local class, but I'm really looking forward to touring some and running in some of the heads up leaf spring classes
Re: Challenger inner fender wells....remove? [Re: Dragula] #1982681
01/03/16 01:48 PM
01/03/16 01:48 PM
Parts unknown
Parts unknown
Pro Mag 44 with a grid, it's so much nicer than when I was trying to pull timing with a six shooter
Re: Challenger inner fender wells....remove? [Re: MR_P_BODY] #1982687
01/03/16 01:55 PM
01/03/16 01:55 PM
Parts unknown
Parts unknown
wave
That's what I was hoping to hear, and that there a no big troubles chopping them out. thanks
