Page 3 of 3 1 2 3
Re: Cylander wall thickness "update" [Re: Chad Bittle] #1981051
01/01/16 02:11 PM
01/01/16 02:11 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
Originally Posted By Chad Bittle
I can't wait, Bill. You're gonna shart yourself lol.
laugh2
Re: Cylander wall thickness "update" [Re: Chad Bittle] #1981387
01/01/16 07:54 PM
01/01/16 07:54 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Well I spent a little time today investigating what the doubters have been saying about calibration's and testing of blocks that seem too good to be true, and what I found in the limited area that I was able to physically check my self and found that on the two cylanders at the rear of the block (#7-#8) mechanically checked out to be the same as what the paperwork said it was,, driverside, the paper said .290 and was real close to what my machinist's scale said it was and #7 had the same results,,so I have convinced myself that his calibration was correct and I have two good blocks to work with. boogie
Re: Cylander wall thickness "update" [Re: dartman366] #1981713
01/02/16 01:14 AM
01/02/16 01:14 AM
You are truly blest bow My brother thumbs I sent my best 400 block (out of the three I have)to the machine shop and it ended up having a pitting issue in one cylinder that the shop decided to put a sleeve in it without asking me before hand and then proceeded to braze and weld up two places on the deck without informing me of the damage which ended up requiring another sleeve in that block on the other side puke runaway Maybe it is time for me to make a machine shop change work
Re: Cylander wall thickness "update" [Re: dartman366] #1981714
01/02/16 01:15 AM
01/02/16 01:15 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
I have convinced myself that his calibration was correct and I have two good blocks to work with. boogie [/quote]
Bill, maybe you should buy the lottery ticket! Oh, and don't forget to share when you win............https://board.moparts.org/ubbthreads/images/icons/default/laugh.gif
Re: Cylander wall thickness "update" [Re: Cab_Burge] #1981889
01/02/16 12:27 PM
01/02/16 12:27 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
one requirement when I have any machine work done is "Here is my home and cell numbers, call me if there is ANY questions or concern's",,,recently I had to change machine shop's because the guy that has done my work finally retired after 35 years and I did a lot of digging and Doug's name kept coming up, so I went for a visit and was pretty impressed with what I heard and seen in his shop, I observed a lot of higher end stuff right along with the standard bracket build's, I have heard a lot of good about him so I am giving him a try and keeping my eyes and ears open and watching how he operates, I like what I have seen so far.
John, my father said once that a blind squirrel will find a nut once in a while, as far as a lottery ticket, well I do have to go and put gas in the truck here in a little while,,,, work
Re: Cylander wall thickness "update" [Re: Chris'sBarracuda] #1982430
01/03/16 12:12 AM
01/03/16 12:12 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Originally Posted By Chris'sBarracuda
Originally Posted By dartman366
had two blocks one was a 1975 the other is a 1976 both came in with the numbers solidly in the .310-.320 range had a spot here and there that was in the mid 200 range worse being 245, and a couple around .260-.280,,95% are .300 or better.
I think I would be questioning the measuring equipment. whistling
Chris. shruggy
Yea Been there done that. I told Bill before hand that what he would get. I think take .100 off them numbers would be closer.
Re: Cylander wall thickness "update" [Re: VernMotor] #1982706
01/03/16 02:46 PM
01/03/16 02:46 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Chris. shruggy
Even if I did reduce the numbers by .100 both block's are good ones.
Re: Cylander wall thickness "update" [Re: dartman366] #1983355
01/04/16 12:42 PM
01/04/16 12:42 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I think everything has been covered as far as the testing and if it was done correctly then you should have a great block.If you went over all the information with your machinist and are satisfied then get started on the build.
The only thing I question is not to use a short fill since your spending a lot of money on the block.The big issue we see is always on the tall fill and block not being clean inside and the cement not sealing against the block and cylinder walls or blocking water passages.But it's your decision as to what gets done.
Good luck with your build,and look forward to seeing you at the track. up
Re: Cylander wall thickness "update" [Re: dartman366] #1983474
01/04/16 03:50 PM
01/04/16 03:50 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
What's the build plan for the block?
I like a little hard block in my stuff but I run my stuff hard.
Re: Cylander wall thickness "update" [Re: dartman366] #1984559
01/05/16 11:21 PM
01/05/16 11:21 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I agree bill I do think the blocks will be fine. Heck I use one. It is in my car LOL It just the odds of me and you owning 4 blocks that check that good. Is pretty rare. I know guys with aftermarket blocks that say they are not that good. And I will add One of the block I got. Been check by two diff shops. Got me? I Quit worrying about it.
Page 3 of 3 1 2 3
