Re: oil pressure problem
[Re: Bigbeep]
#1981747
01/02/16 02:19 AM
01/02/16 02:19 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Well that pan it trash.. how about the headers.. what else did you tear up.. by the way.. thats a BIG wheelie
[Re: Bigbeep]
#1981768
01/02/16 02:55 AM
01/02/16 02:55 AM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
Headers are fine. Lots of little things got damaged. Rear valance, inner fenderwells both are tweaked, hood got cracked where it flexed and hit the fuel line into the barrel valve, front valance flexed and bent, knocked one of the headlights out of the adjusters, header panel slipped out of place as all the dzus fasteners up front connect to it. The worst things are the pan, frame rail on the passenger side got bent upward along with the strut bar on that side, idler arm mount got bent upwards as well.
Was planning on back halfing it with a 4 link and a good set of wheelie bars this winter to address these big dumb wheelies. Been pulling timing at the hit, but obviously I ramped it back in too soon with the mineshaft air we had at the Halloween classic. That wheelie was the first time trial on the sunday warm up race.
Now I think I will be doing both ends of the car this winter if the money holds out. Beep
[Re: sgcuda]
#1981773
01/02/16 03:00 AM
01/02/16 03:00 AM
Bigbeep
Central Ohio, USA
Well, the pic is a keeper. Hope the car didn't get hurt too bad. That's all those big wheelies are good for,......Pictures! As for the car, its fixable. Not cheap, but fixable. I think it will be the old racers adage now. Fix it faster, better, safer. Beep
[Re: Bigbeep]
#1981778
01/02/16 03:12 AM
01/02/16 03:12 AM
Posts: 20,169 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Glad I'm not a wheelie type of guy. If my car does wheelies I fix it before it cost me money. Usually going faster in the process.
[Re: pittsburghracer]
#1981807
01/02/16 04:57 AM
01/02/16 04:57 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
One of the comments I heard at one of the old Mopar Drag race seminars made by one of the Mopar chassis gurus was that if the front tars are off the ground, no matter how high, all of the cars weight is on the hind tars I look for 1/2 inch off the ground on the front tires for a short distance, maybe a tiny bit higher but not much I'm sorry you damaged your car that bad My current E body Cuda carrys the front tires about three inches off for several feet,less than 60 ft., and then puts them back down, it is a lot easier to steer that way
[Re: Bigbeep]
#1981942
01/02/16 01:53 PM
01/02/16 01:53 PM
Posts: 1,030 ohio
67mprfan
ohio
Tough luck John nice wheelie though. Get back together see you at the track
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: Bigbeep]
#1982145
01/02/16 06:05 PM
01/02/16 06:05 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I've got a few of those oil pans,changed out 3 in 3 weeks , finally got rid of the 90/10 shocks , went to stock Monro which keeps the wheelies manageable.
[Re: sgcuda]
#1982261
01/02/16 09:39 PM
01/02/16 09:39 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Uh...Beep, why are you selling those red wheelie bars? Don't you think you might be able to use them? They look good with your headlights. That's what I was thinking, looks like they should've been on the car. LOL
[Re: sgcuda]
#1982348
01/02/16 11:09 PM
01/02/16 11:09 PM
Bigbeep
Central Ohio, USA
Uh...Beep, why are you selling those red wheelie bars? Don't you think you might be able to use them? They look good with your headlights. They look real sweet with the headlights. Problem is the caltracs don't care for them too much. Car unloads tire immediately then will porpoise till I lift. Very hard on the tranny. They were actually at the trailer for sale when that wheelstand happened. Beep
[Re: Bigbeep]
#1982445
01/03/16 12:31 AM
01/03/16 12:31 AM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
Uh...Beep, why are you selling those red wheelie bars? Don't you think you might be able to use them? They look good with your headlights. They look real sweet with the headlights. Problem is the caltracs don't care for them too much. Car unloads tire immediately then will porpoise till I lift. Very hard on the tranny. They were actually at the trailer for sale when that wheelstand happened. Beep . Went threw the same problem wheel stand cost me a lot of Money. Smh
