Re: Best method for draining Challenger fuel tank
[Re: wally426ci]
#1980500
12/31/15 07:28 PM
12/31/15 07:28 PM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
I recently used this to empty 11 gallons out of my Cuda gas tank. http://www.harborfreight.com/multi-use-transfer-pump-66418.htmlTook a little time and energy but was able to transfer all the gas without hardly any mess, though I could still smell gasoline for many hours after I did the transfer.....
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
[Re: loco340cuda]
#1980533
12/31/15 08:08 PM
12/31/15 08:08 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I have used that pump before and it does work. I have an old Holley blue pump with a filter that I use now. Two options with it - either stick a hose down the tank or hook it up to the fuel line.
[Re: ahy]
#1980856
01/01/16 02:31 AM
01/01/16 02:31 AM
RapidRobert
unhook the "out" line from the mech pump & with a neoprene line run it out to the container you are using. take off the air cleaner. let it idle & keep (re)filling the carb bowl till it pumps the tank dry
