69 gtx ? #1979675
12/30/15 10:05 PM
12/30/15 10:05 PM
New Lenox il.
CARMAN Offline OP
CARMAN  Offline OP
New Lenox il.
I currently restoring a 69 gtx and need some info. I am putting on the trim on the outside of the car and when I got to the trim on the top of the doors I realized there are no holes to mount it. Does anyone have a door or car that they could get me some measurements. Thanks for any help.
Re: 69 gtx ? [Re: CARMAN] #1979678
12/30/15 10:10 PM
12/30/15 10:10 PM
69x Offline
69x  Offline
There are no holes there because there should be no trim there
Re: 69 gtx ? [Re: CARMAN] #1979684
12/30/15 10:28 PM
12/30/15 10:28 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Must have changed the doors?
Re: 69 gtx ? [Re: 69x] #1979690
12/30/15 10:35 PM
12/30/15 10:35 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
I know that a 1969 gtx convertible has that trim and I do have door w/the hole may be able to get a look at it this week end
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: 69 gtx ? [Re: 1969gtx] #1979699
12/30/15 10:50 PM
12/30/15 10:50 PM
New Lenox il.
CARMAN Offline OP
CARMAN  Offline OP
New Lenox il.
This car was in boxes when bought. The doors could have been changed at some point. I have only seen one other gtx with this chrome. Here is a pic of the car with the trim on it.
Re: 69 gtx ? [Re: CARMAN] #1979855
12/31/15 01:18 AM
12/31/15 01:18 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
It is an option on hardtops.
Re: 69 gtx ? [Re: NANKET] #1979933
12/31/15 03:07 AM
12/31/15 03:07 AM
Warrenton, VA
Warrenton, VA
Option available on Plymouth B-body post cars too
Re: 69 gtx ? [Re: RoadRunnerJD] #1979955
12/31/15 03:46 AM
12/31/15 03:46 AM
Oh
His and Her 69's Offline
Oh
I would imagine a 69 satellite is the same as the GTX.
I will look and see if my doors have them on it since I have
gutted the doors for parts.
I will check back tomorrow and see if someone posted some photos
and if not I will get some.
David
Re: 69 gtx ? [Re: RoadRunnerJD] #1979967
12/31/15 04:12 AM
12/31/15 04:12 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes I agree, I should have said cars with metal tops. aka hard tops.
68-70 Satellite, Sport Satellite, Road Runner, and GTX all the same. Door trim pieces the same as convertibles. Quarter panel trim is unique to each roof type, 21 23 27. Dodge Coronet quarter panel pieces are different than Plymouth, Coronet door pieces the same as Plymouth. 68-70 Dodge Charger trim is unique in itself and will not interchange with the other B-bodies.
Re: 69 gtx ? [Re: NANKET] #1980108
12/31/15 01:47 PM
12/31/15 01:47 PM
69x Offline
69x  Offline
I have never seen this on a 69 GTX, this would be a rare option. what is this option called and what is the code for it ? does it appear on the fender tag or just the build sheet ?
Re: 69 gtx ? [Re: His and Her 69's] #1980111
12/31/15 01:49 PM
12/31/15 01:49 PM
69x Offline
69x  Offline
David
A satellite would not be the same as a GTX, but maybe a sport satellite.
Re: 69 gtx ? [Re: 69x] #1980133
12/31/15 02:28 PM
12/31/15 02:28 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
its called a belt molding
not sure of the code.. m31 i think?
someone will correct me if i'm wrong..
Re: 69 gtx ? [Re: 69x] #1980151
12/31/15 02:47 PM
12/31/15 02:47 PM
New Lenox il.
CARMAN Offline OP
CARMAN  Offline OP
New Lenox il.
Thanks for the replies. Any pictures or measurements would be greatly appreciated. I would like to know the code for this also so I can look on the build sheet and see if it is there. Like I said this car was in boxes when we got it. All the chrome was wrapped in newspaper and marked. So we assumed this chrome was on the car at one time.
Re: 69 gtx ? [Re: CARMAN] #1980197
12/31/15 03:34 PM
12/31/15 03:34 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Yes, it's M31 ~1489 US spec. GTX hardtops
Re: 69 gtx ? [Re: 69x] #1980270
12/31/15 04:28 PM
12/31/15 04:28 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
It's called "belt line molding" Not that rare of an option on a GTX.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 69 gtx ? [Re: CARMAN] #1980343
12/31/15 05:14 PM
12/31/15 05:14 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
It is on the build sheet M31 Belt mouldings. 1970 RR, Lynch Road, so it is not on the fender tag. Unsure if it is on fender tag of LA and St Louis cars.
A14 Road Runner Spring Special package A: Vinyl roof, chrome styled road wheels, belt mouldings, performance hood paint, sport stripes, sure-grip differential, Fiberglass belted RWL tires F70-14
Re: 69 gtx ? [Re: CARMAN] #1980499
12/31/15 07:28 PM
12/31/15 07:28 PM
Chicago
PurpleBeeper Offline
Chicago
Honestly, it depends on how "concours" you want to be with your restoration. I ran into this exact issue when I modified a '68 hardtop door to put on my '70 convt. (all verts have this molding). The clips behind the trim can slide left/right within the trim, so you just need one clip on each end of the trim piece and a few more in the middle. I did mine by measuring the other side and copying it.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 69 gtx ? [Re: CARMAN] #1980543
12/31/15 08:19 PM
12/31/15 08:19 PM
Warrenton, VA
Warrenton, VA
FYI, see if you have the correct trim pieces. The belt molding on a coupe is different than the one for a convertible/hardtop. It has a notchout on the end that meets the quarter panel similar to the notch where it meets the vent window frame. The trim piece for hardtop/convertibles is only notched at the end where it meets the vent wing.
Re: 69 gtx ? [Re: RoadRunnerJD] #1980615
12/31/15 09:21 PM
12/31/15 09:21 PM
New Lenox il.
CARMAN Offline OP
CARMAN  Offline OP
New Lenox il.
Here is a pic of the trim. It has a notch on one end for the vent.
Re: 69 gtx ? [Re: CARMAN] #1980670
12/31/15 10:28 PM
12/31/15 10:28 PM
cmansell Offline
cmansell  Offline
Is the inside door lock in the wrong place for a 69?
