Question about bronze gears #197929
01/19/09 11:25 AM
01/19/09 11:25 AM
Anonymous OP
Anonymous OP
Are the BB bronze distributor gears the same dimensionally as the stock steel(iron?) ones?
Or do roller cams use a different size as well as material?
Market research on my part.
TIA.
Re: Question about bronze gears #197930
01/19/09 11:53 AM
01/19/09 11:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would think they are the same but I dont have a
pair in the shop to measure. I would think the factory
would make them the same due to a cost factor, make
everything the same is easy
Re: Question about bronze gears [Re: MR_P_BODY] #197931
01/19/09 12:02 PM
01/19/09 12:02 PM
Anonymous OP
Anonymous OP
I would think so, too, but just thought I'd check on here.
Thanks!
Re: Question about bronze gears #197932
01/19/09 01:55 PM
01/19/09 01:55 PM
smyrna,tn
draginmopars Offline
smyrna,tn
I have found that the drives are the same, that only the shaft is longer on my mag drive (on right)
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Question about bronze gears [Re: draginmopars] #197933
01/19/09 05:52 PM
01/19/09 05:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yup standard pump standard length. no a big milidon pump has a longer one and a get up hear were the extra line is on a plate between the pump and the block takes a longer one yet
Re: Question about bronze gears [Re: Dodgem] #197934
01/19/09 07:00 PM
01/19/09 07:00 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Not trying to hi-jack the thread but, if you run a roller cam, bronze gear and thrust bearing should you machine the block to allow for the thrust bearing. I have had excessive wear on one side of 2 gears now. The old block the gear did not show any signs of wear after many seasons but I don't know if it was machined for thrust bearing.
Re: Question about bronze gears [Re: mac56] #197935
01/20/09 02:13 AM
01/20/09 02:13 AM
Anonymous OP
Anonymous OP
Thanks for the confirmation, guys! If things pan out, you street guys wanting to run roller BBs will have a better(far more durable than bronze) part soon. One less thing to worry about going that route.
Re: Question about bronze gears #197936
01/20/09 02:31 AM
01/20/09 02:31 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Let me guess....
It will be made of high density plastic.
MB
Re: Question about bronze gears [Re: HPMike] #197937
01/20/09 08:13 AM
01/20/09 08:13 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Let me guess....
MB
I looked into making the composite gears last year but found the proper material was more than 10x the price of bronze.
Maybe you have found something cheaper.
I would love to get away from the bronze
Good luck.
Re: Question about bronze gears [Re: HPMike] #197938
01/21/09 12:00 PM
01/21/09 12:00 PM
Anonymous OP
Anonymous OP
If you mean the carbon ultra-poly material, yes, that's what I'm looking into. It costs more, but then, it doesn't wear out nearly as quick(if ever). Haven't been serious about it for awhile. Last time I was, I couldn't locate a raw material source. I admittedly didn't look very hard.
Seems to work well for the ford,chevys,pontiacs,buicks,etc that they're otherwise available for. I realize SB mopars can just use the factory Magnum part for the gear in that application. I'm just surprised noone else has filled the niche already.
Re: Question about bronze gears #197939
01/21/09 02:50 PM
01/21/09 02:50 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I got a piece form a place called poly-tech in North Carolina.
It was about $50 for a 2" piece to make a prototype gear and that was a deal because he had an off cut laying around.
Re: Question about bronze gears [Re: The Shadow] #197940
01/22/09 01:41 AM
01/22/09 01:41 AM
Anonymous OP
Anonymous OP
I'll check that out!
Re: Question about bronze gears #197941
01/22/09 07:54 AM
01/22/09 07:54 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
very soon? how very soon?
Re: Question about bronze gears [Re: VanishPt] #197942
01/22/09 08:34 AM
01/22/09 08:34 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
is this soon as in this year?
Re: Question about bronze gears [Re: bonefish] #197943
06/17/09 09:07 PM
06/17/09 09:07 PM
V
VanishPt Offline
VanishPt  Offline
V
any new info on the gear?
