ring gear bolts #1977284
12/27/15 06:08 PM
12/27/15 06:08 PM
pennsylvania
poboyengineering Offline OP
pennsylvania
Dumb question of the day- locktite on ring gear bolts, yes or no?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: ring gear bolts [Re: poboyengineering] #1977286
12/27/15 06:08 PM
12/27/15 06:08 PM
Park Forest, IL
slantzilla Offline
Happy Birthday slantzilla  Offline
Park Forest, IL
I use it.
Re: ring gear bolts [Re: poboyengineering] #1977288
12/27/15 06:12 PM
12/27/15 06:12 PM
Kirkland, Washington
Pacnorthcuda Offline
I use it too.
Re: ring gear bolts [Re: poboyengineering] #1977290
12/27/15 06:15 PM
12/27/15 06:15 PM
pennsylvania
pennsylvania
I assumed so, but thought I would check first.
Re: ring gear bolts [Re: poboyengineering] #1977297
12/27/15 06:32 PM
12/27/15 06:32 PM
pennsylvania
pennsylvania
One more question.....torque? 8 3/4, 489 case, spool, new bolts.
Re: ring gear bolts [Re: poboyengineering] #1977311
12/27/15 06:56 PM
12/27/15 06:56 PM
Mopar used left hand threads to prevent bolts from coming loose so no need for locktite on 8 3/4 bolts. The Hi Po replacement Mopar bolts from Direct Connection and Moparts use to come with a coating on them, the original OEM factory ones didn't shruggy It won't hurt to use a thread locker if you want, I wouldn't use the Red or Green Locktite though twocents As far as torque the FSM calls for 55 ft lbs is what I remember and use thumbs I had to buy a 1/2 inch drive Snap On torque wrench that would measure torque on left hand threaded bolts, My Proto and Craftsmen clicker wrenches wouldn't confused
BTW which brand bolts are you using and what do they recommend for the torque? Use and follow thier recommndations thumbs
Re: ring gear bolts [Re: poboyengineering] #1977327
12/27/15 07:16 PM
12/27/15 07:16 PM
pennsylvania
pennsylvania
Cab, I got the bolts with the bearing kit from DrDiff. No coating on them.
Re: ring gear bolts [Re: poboyengineering] #1977334
12/27/15 07:27 PM
12/27/15 07:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the red locktite on them..when I change gears
I use a impact and they come out with no problem...
I use the factory specs
wave
Re: ring gear bolts [Re: poboyengineering] #1977412
12/27/15 09:23 PM
12/27/15 09:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Many ring gear bolts have a locking plastic insert in the threads.
Re: ring gear bolts [Re: poboyengineering] #1977422
12/27/15 09:42 PM
12/27/15 09:42 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I use red Loc-tite on the threads and a dab of ARP lube under the bolt head on all my ring gear installs twocents
Gus beer
64 Plymouth Savoy
Dana 60
