TC too tight? #1976608
12/26/15 04:16 PM
12/26/15 04:16 PM
Chattanooga, TN
KDY Offline OP
KDY  Offline OP
Chattanooga, TN
Hey guys looking for a little help on my street/strip truck
Currently I'm running a 9.5" PTC that flashes 3900 or so. Shift at 5500, fall back is around 1300.
Motor is a mild 440, 727, D60 with 4.10s, 28.5x9 slick, truck weighs 3800lb with me in it. Best So far is 7.66 @ 88.
I am looking to make some changes over the winter:
I will be swapping the .502/.511 236/242 @ 0.05" cam to a .555/.555 260/260 @ 0.05" cam
And the I'll be swapping the Street Dominator for a Victor
I'm thinking the TC is a little tight for my application? Is there ET to be gained going looser?
Video of the truck:
http://youtu.be/pZnCu63JymI
Any advise is appreciated!
Re: TC too tight? [Re: KDY] #1976849
12/26/15 11:51 PM
12/26/15 11:51 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
With the new cam the vert will be a little tight but not to bad. A 4800 stall vert would be quicker. Also, with the weight of that truck I would stick with the street dominator intake vs the victor if you Don't change the vert. If you do the vert change the victor will be fine.
PTC should be able to loosen that vert up for you.
Re: TC too tight? [Re: KDY] #1977037
12/27/15 12:21 PM
12/27/15 12:21 PM
Chattanooga, TN
KDY Offline OP
KDY  Offline OP
Chattanooga, TN
Thanks for the input!
I will definitely be making one change at a time starting with the cam. From there I can test the intake and see what happens to the stall.
4800 was the number I had in the back of my head as well. Based on dyno numbers from similar 440 builds peak torque seems to fall around 4500 give or take.
My only concern would it be too much for the occasional cruise on the street? I'm thinking no...
Re: TC too tight? [Re: KDY] #1977040
12/27/15 12:30 PM
12/27/15 12:30 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
I ran a 5,200 RPM converter on the street. As long as you have a GOOD trans cooler and don't make it a daily driver you will be fine. The biggest issue (at least for me) was the MPG or lack of. Gets expensive quick when you are running race gas and a race converter on the street. But yes, you could cruise it with the 4,800.
Re: TC too tight? [Re: Tempest] #1977143
12/27/15 02:45 PM
12/27/15 02:45 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been running an 8" 5000+ Continental vert on the streets for 10+ years w/a GOOD B&M cooler bypassing the radiator and trans never gets over 180 even in 112+ Vegas heat on the fwy.........
Re: TC too tight? [Re: Thumperdart] #1977366
12/27/15 08:24 PM
12/27/15 08:24 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What does it 60 ft now ? Ron
Re: TC too tight? [Re: KDY] #1977478
12/27/15 10:55 PM
12/27/15 10:55 PM
Chattanooga, TN
KDY Offline OP
KDY  Offline OP
Chattanooga, TN
Best of a 1.636 in great air and fresh slicks.
Re: TC too tight? [Re: KDY] #1977514
12/27/15 11:30 PM
12/27/15 11:30 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
That 60 ft. is inline with your ET that you run now with your current combo. That wont be the case with the new cams duration of 260 @ .050 vs 236 @ .050 with the current cam. Im assuming the 236 @ .050 is hyd.
Re: TC too tight? [Re: KDY] #1977538
12/27/15 11:45 PM
12/27/15 11:45 PM
Chattanooga, TN
KDY Offline OP
KDY  Offline OP
Chattanooga, TN
Cams are solid sir.
Re: TC too tight? [Re: KDY] #1977575
12/28/15 12:28 AM
12/28/15 12:28 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
.Even the current 236* @ .050 is solid, that's uncommon for the most part, being that small.
Both cams being solids make them act about 10* smaller @ .050 then their advertised numbers with lash. So that will make a lessor stall vert more versatile with your combo. Still ,I would go with a tight vert around 4800 to 5200 max.
Re: TC too tight? [Re: KDY] #1977774
12/28/15 11:11 AM
12/28/15 11:11 AM
Chattanooga, TN
KDY Offline OP
KDY  Offline OP
Chattanooga, TN
I appreciate the help. I will get the cam in it over the winter and see how it effects the stall - then decide how much to loosen it. I agree that 4800 is about what I want to shoot for in the end.
Basically I'm just trying to wring some numbers out of this combo by sorting it out. Its cheaper than building a bigger engine!
