mini spring tester #1974390
12/22/15 10:31 AM
12/22/15 10:31 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
has anyone used those mini spring testers that use a vice to compress the spring.good or bad?
Re: mini spring tester [Re: bonefish] #1974410
12/22/15 11:08 AM
12/22/15 11:08 AM
NY
mopar 12 Offline
mopar 12  Offline
NY
I've used one, works good just have to have a big jaw vise, maybe 4-6 inches, mine is 6"
Re: mini spring tester [Re: bonefish] #1974412
12/22/15 11:12 AM
12/22/15 11:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use it a lot.. I like it.. its simple.. I use
a set of calipers along with it.. set it at the
install height and crank it up
wave
Re: mini spring tester [Re: bonefish] #1974511
12/22/15 01:35 PM
12/22/15 01:35 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The first one I bought (Proform 0-300# or something comparable?) was a piece of junk. I also have a claibration spring and it was nowhere near accurate. IIRC, it started off OK, then started getting more "off" after using it only a few times.
The second one I bought was a 0-600# from a board member (vendor) whose name I cannot recall at the moment, unfortunately. That one has worked fine. Maybe he'll see this thread and pipe in.
Re: mini spring tester [Re: BradH] #1974883
12/23/15 12:16 AM
12/23/15 12:16 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
That brings up a good question,i was looking at a proform 0-700 unit.witch one are you guys usin?
Re: mini spring tester [Re: bonefish] #1974886
12/23/15 12:28 AM
12/23/15 12:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have the 300and the 700.. they are both the same
but a different gauge on it... I also have a 1000
psi gauge that I screwed on to one for testing the
open pressure on my W-9 heads.. 900# springs
wave
Re: mini spring tester [Re: bonefish] #1975013
12/23/15 04:57 AM
12/23/15 04:57 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
I've had the 0-700 Proform for a couple years now and has worked good for my needs. I tested it when I first got it and found it was reasonably accurate($72 bucks worth of accurate anyways) wink I loaned it to a buddy a few weeks ago and he liked it so much that he bought one too. He said he compared the two testers with same spring and said they repeated the same but, he still hasn't returned mine xmaseek
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: mini spring tester [Re: MoParFish] #1975046
12/23/15 10:29 AM
12/23/15 10:29 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
I think I have the same buddy! nervous
Re: mini spring tester [Re: mopar 12] #1975063
12/23/15 11:45 AM
12/23/15 11:45 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
A small arbor press works good with them.
If you like drag racing, support your local track.
