Re: mini spring tester
[Re: bonefish]
#1974412
12/22/15 11:12 AM
12/22/15 11:12 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I use it a lot.. I like it.. its simple.. I use a set of calipers along with it.. set it at the install height and crank it up
[Re: BradH]
#1974883
12/23/15 12:16 AM
12/23/15 12:16 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
The first one I bought (Proform 0-300# or something comparable?) was a piece of junk. I also have a claibration spring and it was nowhere near accurate. IIRC, it started off OK, then started getting more "off" after using it only a few times.
The second one I bought was a 0-600# from a board member (vendor) whose name I cannot recall at the moment, unfortunately. That one has worked fine. Maybe he'll see this thread and pipe in. That brings up a good question,i was looking at a proform 0-700 unit.witch one are you guys usin?
[Re: bonefish]
#1974886
12/23/15 12:28 AM
12/23/15 12:28 AM
MR_P_BODY
The second one I bought was a 0-600# from a board member (vendor) whose name I cannot recall at the moment, unfortunately. That one has worked fine. Maybe he'll see this thread and pipe in. That brings up a good question,i was looking at a proform 0-700 unit.witch one are you guys usin? I have the 300and the 700.. they are both the same but a different gauge on it... I also have a 1000 psi gauge that I screwed on to one for testing the open pressure on my W-9 heads.. 900# springs
[Re: bonefish]
#1975013
12/23/15 04:57 AM
12/23/15 04:57 AM
Posts: 485 Central California
MoParFish
Central California
The second one I bought was a 0-600# from a board member (vendor) whose name I cannot recall at the moment, unfortunately. That one has worked fine. Maybe he'll see this thread and pipe in. That brings up a good question,i was looking at a proform 0-700 unit.witch one are you guys usin? I've had the 0-700 Proform for a couple years now and has worked good for my needs. I tested it when I first got it and found it was reasonably accurate($72 bucks worth of accurate anyways) I loaned it to a buddy a few weeks ago and he liked it so much that he bought one too. He said he compared the two testers with same spring and said they repeated the same but, he still hasn't returned mine
[Re: MoParFish]
#1975046
12/23/15 10:29 AM
12/23/15 10:29 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
The second one I bought was a 0-600# from a board member (vendor) whose name I cannot recall at the moment, unfortunately. That one has worked fine. Maybe he'll see this thread and pipe in. That brings up a good question,i was looking at a proform 0-700 unit.witch one are you guys usin? I've had the 0-700 Proform for a couple years now and has worked good for my needs. I tested it when I first got it and found it was reasonably accurate($72 bucks worth of accurate anyways) I loaned it to a buddy a few weeks ago and he liked it so much that he bought one too. He said he compared the two testers with same spring and said they repeated the same but, he still hasn't returned mine I think I have the same buddy!
[Re: mopar 12]
#1975063
12/23/15 11:45 AM
12/23/15 11:45 AM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
I've used one, works good just have to have a big jaw vise, maybe 4-6 inches, mine is 6" A small arbor press works good with them.
If you like drag racing, support your local track.
