67 B body Autocross set up?
#1972287
12/18/15 08:08 PM
12/18/15 08:08 PM
Posts: 7,480 Minnesota
Hemi_Joel
Minnesota
What are the first, most simple and quick steps to get a stock 67 B body ready to autocross?
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: 67 B body Autocross set up?
[Re: Hemi_Joel]
#1972290
12/18/15 08:20 PM
12/18/15 08:20 PM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
First: BIG anti-sway bars. And get some sticky tires at the same time regardless what bars or springs you have or get. Non sticky tires just won't work regardless what else you do with the car.
Second: bigger torsion bars - big heavy car = 1 1/4" at least.
Third: frame connectors.
Forth: heavier/bigger/better rear springs.
Fifth: better shocks to go with the springs and t-bars.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: Hemi_Joel]
#1972453
12/19/15 01:02 AM
12/19/15 01:02 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
A good oil pan, I like the Milodon road race pans. I have the idea that Bergman tbars and big brakes are in your future young Jedi.....I am trying to figure out how to install carbon ceramic metallic rotors and 6 piston brembo calipers....
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: BigBlockMopar]
#1972644
12/19/15 01:51 PM
12/19/15 01:51 PM
amxautox
No.3 should (already) be done on all Mopars, regardless of their use Well, ya. But... Most of us have to do things in steps as the paydays come around.
Tom
author unknown
[Re: Hemi_Joel]
#1972903
12/19/15 09:12 PM
12/19/15 09:12 PM
Posts: 801 central CT
cudazappa
central CT
Easiest way to get your car ready, is to inflate the tires to max and enter an event! One thing I learned through the years is the driver is the biggest component, and a novice constantly changing his/her car can impeed learning. But in changing a stock car to getting it ready to autocross this is the order I would go in: 1) alignment: get some positive caster, negative camber, and a skosh of toe in. Use the Moog bushings and it will be much easier to get that. If not, you may need UCAs, but this is where it all starts. 2) 200 treadwear tires as wide as possible. Tires make the most difference when transforming a car. However, the difference is two fold. While a sticky tire is faster, it forgives many mistakes. That can slow down learing the fast way around a course. Locally I chase down cars on 50tw tires on my 200tw tires. I'm not the best driver but last time out I wasn't last in my class, either. 3) Frame connectors. If not done already, they can be done as cheaply or as expensive as you want. Go to a steel supplier and fab your own or buy the latest and greatest contour fit. Something is better than nothing. Get a bolt in set and bolt them in, take them to an exhaust shop and get them welded in. 4) sway bars. Go big in front, like 1 1/4. For the rear, start small. If the car still wants to push and not rotate, go bigger. Repeat until the car just wants to kick out to your driving style. 5) shocks. Get good single adjustables to start. You can stiffen them up for racing and then soften them for the drive home. If you go big torsion bars and keep cheap-ish shocks, you may hate the ride on the car over roads. That's why I say shocks first.
That's where I'd start. Don't worry about oil mods at first unless you're triggering the oil light. a good oil pan isn't cheap, and changing one while the engine is in the car isn't always easy. Changing spring rates is also easy, but it gets more expensive, and again, a lot is driver preference. There are some of us that like the large 1.18, 1.22 and 1.24 bars. Hotchkis, among others, recommends a smaller bar. It all depends how hard core you go, really. There's a lot more to go, as with any motorsport. How fast do you wanna go? $$$$$
1971 Challenger
[Re: Hemi_Joel]
#1972923
12/19/15 09:43 PM
12/19/15 09:43 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Thanks, Joel Just show up and try the car the way it is, lots of times you will find the car stalls or leaks. After that you can start to dial it in, first things I would change is the torsion bars and front shocks.
A new iron curtain drawn across the 49th parallel
[Re: Hemi_Joel]
#1973428
12/20/15 08:08 PM
12/20/15 08:08 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
You may want to pick up a copy of Andy F's book on b-body handling. LOTS of good info in there to digest.
Carl Kessel
[Re: Hemi_Joel]
#1973552
12/21/15 12:30 AM
12/21/15 12:30 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
18x9 or wider wheels and 275/35/18's in a 200tw tire would be my first additions. With a tire/wheel package that is capable you will better know what the suspension needs. All the suspension mods in the world won't matter with g60/14's.
Mopar to the bone!!!
[Re: Hemi_Joel]
#1973603
12/21/15 01:55 AM
12/21/15 01:55 AM
Hemi_Joel
Minnesota
[Re: 72Swinger]
#1973619
12/21/15 02:19 AM
12/21/15 02:19 AM
Posts: 27,467 So Cal
autoxcuda
So Cal
18x9 or wider wheels and 275/35/18's in a 200tw tire would be my first additions. With a tire/wheel package that is capable you will better know what the suspension needs. All the suspension mods in the world won't matter with g60/14's. I agree. And fitting wide front and rear tires on a 66-67 B-body will take lots of homework, thought, and skillful metal manipulation if you want it to look subtle. Might consider of making room to 315's on all four corners if you are looking to be competitive. I'd be thinking of using the natural front fender flare that 66-67 s have. Maybe manipulating it upwards, thinning it, angling it out more, etc. In the rear mini tubs would keep the flat quarter still flat.
[Re: CKessel]
#1973915
12/21/15 05:10 PM
12/21/15 05:10 PM
Posts: 1,668 Caldwell, Idaho
67R/T4speeder
Caldwell, Idaho
You may want to pick up a copy of Andy F's book on b-body handling. LOTS of good info in there to digest. Where can I get this book? I am interested.
[Re: 67R/T4speeder]
#1973946
12/21/15 05:46 PM
12/21/15 05:46 PM
amxautox
You may want to pick up a copy of Andy F's book on b-body handling. LOTS of good info in there to digest. Where can I get this book? I am interested. http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dstripbooks&field-keywords=Andy+Finkbeiner >>> click link <<<
Tom
author unknown
