Re: Heater Box Plastic repair
[Re: DusterJeff]
#1972101
12/18/15 01:53 PM
12/18/15 01:53 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Jeff, no, the ABS/Acetone mix would not be the way to go. Heater boxes are made of RIM molded plastic (Reaction Injection Molding) it's much like a fiber reinforced epoxy that is cured under heat and pressure. It does not have the typical characteristics of injection molded resins. Repairs can be made with two part epoxies, I like this stuff: http://www.jbweld.com/products/highheat-epoxy-puttyLarger patches can be reinforced with a patch of fiberglass window screen. After smoothing it over you can sand and paint to blend. .02
[Re: DusterJeff]
#1972154
12/18/15 03:21 PM
12/18/15 03:21 PM
Posts: 1,025 NJ
EV2RTSE
NJ
